a repository for a synology package
Postby greee » Fri Apr 01, 2016 12:40 pm
Synology is the first NAS manufacturer, it is very popular.
And this is an obvious place to store all music files (to avoid loosing it).
Unfortunately, there is no package for DSM environment (DSM is the Operating System running on every Synology NAS).
There is not, either, clear and easy tutorial
The latest version of DSM (version 6) just came out, and Subsonic can rely on Java (which exists on DSM, there is now a package which is maintain directly by Synology Inc.)
Subsonic has many advantages compared to the tools provided with DSM and I like it for so long :)
Also I would love to see a repository compatible with DSM to be implement by Subsonic or some good spk packages.
Thank you in advance.
greee
Re: a repository for a synology package
Postby alphawave7 » Sat Apr 02, 2016 3:20 am
Postby greee » Sat Apr 02, 2016 11:40 am
Thank you @alphawave7 but this not really help cause DSM 6 seems to have change too many things
I can't no more start/stop Subsonic on new DSM 6 interface (I tried with subsonic 6 beta 2)
A new package is really wanted :-/
greee
Postby ozzyrb5 » Sun Apr 03, 2016 10:28 pm
This works for me on my Synology DS125j
https://github.com/ghenry22/Subsonic_Synology
Latest issue I have with DSM 6 is the redirect of port 80 is via Nginx and is causing me nothing but grief to disable. I still have it running, but only on a custom port e.g. 4040
Another issue I have since upgrading to Beta 2 and DSM 6 is my Sonos timesout on a couple of larger folders I have. seems (for me) to be a limit of 148 items in the folder
Stefan
ozzyrb5
Postby ozzyrb5 » Sun Apr 03, 2016 10:39 pm
Just to say too, that when I want to upgrade Subsonic I simply copy across the WAR file
Stefan
ozzyrb5
Postby greee » Wed Apr 06, 2016 10:20 am
thank you for the link @ozzyrb5
For now, I also update Subsonic copying files (war and jar) to my Synology NAS
But it is really a lesser evil, you can't start / stop / upgrade Subsonic from the dedicated tool on Sylogy DSM :-(
It make the Subsonic solution oscur and too tricky for regular users to choose it, it's a pity for me as I reaaly think that Subsonic is one of the best solution for people to reclaim their music :cry:
greee
Postby greee » Sat Apr 09, 2016 4:17 pm
in fact, subsonic doesn't start on my synology boot
If I try to lauch it by software center, it fails (but finally runs in background...)
SO it's a real mess
I and all Synology users ( I repeat this is the first NAS vendor !!!) need a better support please
greee
Postby greee » Tue Apr 19, 2016 2:00 am
please, if you think like me that this feature is really a good thing that should become reality quick, reply and you say "+1". thanks
greee
Postby DownUnder » Sat Jun 04, 2016 4:22 am
+1
It seems that about once/twice a year I go looking for a Synology/Subsonic solution for my large music and audio collection to use with Sonos. Every year I read a dozen forum posts which express the pain of tweaking obscure parameters or the incompatibility of specific devices.
Can't believe there is still no out-of-the-box installable solution!
DownUnder
Postby gregsinibaldi » Sat Sep 03, 2016 5:19 pm
+1 +1 +1!
gregsinibaldi
Postby PierreC31 » Sun Sep 04, 2016 1:02 pm
+1
I do love Subsonic... and i am so sad it no longer works on DSM6..!!!
PierreC31
