shuffle control integrated into mini-player
Postby williamkray » Fri Apr 22, 2016 5:48 pm
I think the new web interface is a vast improvement over the old, but there's still one change that hasn't happened, and it's annoying from a usability standpoint: the web player playlist only has the option to shuffle music if you scroll aaaaallllllllllllllllllllll the way down to the bottom of the current play queue. which is a total pain if you load up a playlist, but want to shuffle it. this should be another shortcut button like the repeat option. I feel like it also shouldn't be a function of the play queue itself (literally shuffling the order of the songs within the queue), but rather how the player chooses the next song to play (so you can toggle shuffle mode on or off); but that's a whole other logistical issue so i won't expect that kind of thing any time soon.
just a recommendation :)
EDIT: Just noticed that this post says exactly the same thing: viewtopic.php?f=3&t=16560
williamkray
Re: shuffle control integrated into mini-player
Postby toolman » Sun Apr 24, 2016 2:06 pm
Perhaps it's a good idea to upvote the other posting as well.
I for one do support your request because it is quite annoying to have to scroll down all the way.
I think that the mini-player should have all the controls like play, pause, previous, next, shuffle and loop.
If it is possible to add a Star-rating option to the player, it should be possible to include a Shuffle-option.
toolman
