Bulk import of playlists
Postby Dec » Mon Sep 25, 2017 6:49 pm
I have many playlists for various subjects split over 5 windows directories. Presently I have to choose every playlist manually and import it.
A bulk import or bulk update of playlist that are in main directory (with sub directory scanning) would be great.
Dec
Re: Bulk import of playlists
Postby Jägs » Tue Sep 26, 2017 1:16 am
If you put your playlists in the folder specified under Settings --> General --> Import Playlist from, Subsonic will import these playlists every time it does a scan. Will this not suffice?
Jägs
Postby Dec » Sun Oct 01, 2017 11:40 am
HI Jägs,
thanks for your input. I had configured the path in the correct way but I wasn't aware that subsonic only takes into account the m3u files that are stored in the main directory. m3u files that are in subdirectories were not imported. I will copy all my m3u files into the main configured directory (which will create a little mess) but bulk import works.
Dec
Dec
