Option to choose folder.jpg, cover.jpg or something else
Postby 3Dscrewer » Sat Feb 17, 2018 11:00 am
So far it is all told in subject. It is annoying if there are different pictures in the folder i.e. back.jpg that Subsonic will show that as a Cover picture.
I am using also Kodi as an Mediaserver, that will save a lots off pictures in the album folder.
So if there is no Cover in Meta-Tag there should be an option to ask for the name of the cover AND to disable it at all, if someone like it
3Dscrewer
Re: Option to choose folder.jpg, cover.jpg or something else
Postby wendigo » Thu Feb 22, 2018 5:51 pm
It is there under Settings > General. In "Cover art files" you can specify filename patterns you prefer. I use these for example: "cover.jpg cover.jpeg Cover.jpg cover.png cover.gif front.jpg Front.jpg front.jpeg folder.jpg jpg jpeg gif png".
Not sure if it supports some asterisk convention though.
If none of those is present in the folder Subsonic defaults to alphabetical order of image files.
wendigo
