Deny Folders by User
Postby bstrdsmkr » Sat May 02, 2009 10:14 pm
It would be nice to be able to enable or disable a folder by user.
Maybe a recursive list of folders under user settings with check boxes to enable/disable access to certain folders. This could also be a great way to enable/disable uploading to certain folders. Seems like this could cause a bit of unnecessary processing every time you opened the setting dialog though. Maybe a link to a popup window that generates the list onload?
Possibly have it output to an .ini file that would be read while populating the list onload EG:
[admin]
c:\folder1 access = 1;
c:\folder1 upload = 1;
c:\folder2 access = 1;
c:\folder2 upload = 0;
then you could populate that user's list box with the allowed folders when uploading
I'd be glad to help, i'm just not very strong in jsp, but i'm decent with javascript :)
bstrdsmkr
Postby jigsaw » Sat May 02, 2009 11:08 pm
I would suggest adding your request to this post:
http://forum.subsonic.org/forum/viewtopic.php?t=1768
As you may find by searching on the forum this as been requested several times before. If more people request it, it may get higher priority by Sindre :)
jigsaw
