Synology DSM 7.0 - Subsonic 6.1.6 no longer works ...
Postby CreeperX » Wed Sep 01, 2021 4:44 pm
i upgraded to DSM 7.0. after the Update Subsonic 6.1.6. works no longer.
It says its not compatible with my DSM Version.
Is there a Update planned to make it compatible with DMS 7.0 again ?
THX !
Allready miss it .. and there is no way back to DSM 6.xx.
Greets
Peter
CreeperX
Re: Synology DSM 7.0 - Subsonic 6.1.6 no longer works ...
Postby Jägs » Thu Sep 02, 2021 1:51 am
There hasn't been a Subsonic update in nearly two years, so I don't think you'll have any luck getting any support. That said, have you tried Airsonic? It's a fork of Subsonic with the fee requirements stripped out. It's since been forked to Airsonic Advance, and while I couldn't find a Synology package for that, there's a specific build of Airsonic for Synology:
https://github.com/ghenry22/airsonic-sy ... g/1_0_1062
I switched to a NAS last year and kind of saw the writing on the wall with the *sonic releases, so I took a look at Koel, Navidrome, etc., and ultimately settled on Emby, as I was already using it for video. It still not as good as Subsonic was for my music needs—it's first and foremost a video streamer—but it is under active development and getting better with each release.
Jägs
Postby CreeperX » Fri Sep 03, 2021 11:33 am
Hi..
thx for your reply. I tried the Packages .. but i m not able to install them manually because of an Error about wrong File Format .. maybe because its not signed ?
I also tried to run Airsonic via Docker .. but im not abel to open the Airsonic Webpage after install.
So i have to wait for some new Versions supporting DSM 7.0.
I use this to get all my Music to Sonos .. Sonos can not handle the amount of files direcly.
so .. I m running Emby atm .. thx for the hint !
Greets
Peter
CreeperX
