How to add a good song how to join the playlist
Postby huang » Tue Dec 21, 2021 3:20 am
How to add hundreds of songs to a playlist, batch operation
huang
Re: How to add a good song how to join the playlist
Postby J_T_W » Tue Dec 21, 2021 6:46 pm
Easiest is to create a standard playlist file (.m3u / .m3u8) in a folder visible to whatever account you're running Subsonic under. Make sure your list uses the same root for your music files as you have configured within Subsonic under Subsonic\Settings\Media Folders. From Subsonic\Settings\General, specify that path under the "Import playlists from" field, then under Subsonic\Settings\Media Folders, trigger a scan.
J_T_W
