A list of features
A list of features
Postby eivindcom » Tue Jan 17, 2006 11:03 am
First of all i love this system! I share my entire music collection and i also allow my close friends and family access to it. Sometimes i have 5-8 users playing at the same time with no problems. There are a few features i would like to accomodate multiple users.
Here goes:
- Change player settings for all players (global)
Mainly to disable pictures for all users
If a folder contain loads of files the pictures fill up a lagre portion of the frame and the actual files/folders is centered and starts half way down the frame.
- Download playlists og saved playlist
To simplify download of a user spesific list
- Interactivity with users
Let users report wrong/bad songs trough a internal message system
Let users request missing songs/albums trough a form.
This form could show up as a list for the admin where you can removed the when the music have been added.
- Log
Keep a longer log file (Mine just logs a day or so)
Sindre send me a PM if you would like access to my music
6 982 artister
2 742 album
31 872 sanger
Totalt 134,26 GB (~ 2 085 timer)
Thank you!
Eivind
Stavanger, Norway
eivindcom
Re: A list of features
Postby sindre_mehus » Tue Jan 17, 2006 3:38 pm
Hi Eivind, and thanks for your comments!
eivindcom wrote:- Change player settings for all players (global)
At least, I'll try to fix the layout problem. (The file/folder list is top-aligned in Opera, but not in Firefox and IE).
eivindcom wrote:- Download playlists og saved playlist
Yes, this would be a nice feature. Will be implemented.
eivindcom wrote:- Interactivity with users
Hm, yeah maybe it would be neat with some bulletin board functionality along the lines you describe. I'll keep it in mind.
eivindcom wrote:- Log
Are you thinking about the log which is displayed in the web page, or the actual log file on disk (TOMCAT_HOME/logs/subsonic.log)? The latter keeps all log lines since Tomcat was restarted. If you refer to the web page, I could at least add an option to show more of the log. Maybe also an option not to display debug messages?
eivindcom wrote:Sindre send me a PM if you would like access to my music
That's very kind of you :D
Postby eivindcom » Tue Jan 17, 2006 6:26 pm
A PM has been sendt, enjoy!
I was thinking about a "simple" form to add some text to a list for the admin. Maybe one list to report bad/wrong songs. It cold be a button next to the song called Report, this would bring up a form where the user cold fill in what the problem was and the form would know the path to the song and the username.
Another function could be a request for new album/artist/song form. This would populate a list that the admin could view and delete as the music is in place. This list could be viewable to all user.
Thanks again!!
eivindcom
Postby eivindcom » Tue Jan 17, 2006 6:37 pm
By the way i figured out a way to disable images globaly..
I removed all the text in the "Cover art mask" box under settings.
This saves a lot of resources on my server, but i miss it a little bit.
No more images, but i would like ONE to show up under each album.
Maybe a image limit pr view would function better?
I had one folder with some 100 different artists and i loaded images for ever...
Eivind
eivindcom
Postby sindre_mehus » Tue Jan 17, 2006 9:11 pm
eivindcom wrote:Maybe a image limit pr view would function better?
Good point. I'll come up with something (for instance a configurable limit).
-Sindre
Postby eivindcom » Thu Jan 19, 2006 2:37 pm
Did you get this information?
Maybe you missed it since i posted twice in a row...
Eivind
eivindcom
Postby sindre_mehus » Thu Jan 19, 2006 3:11 pm
Yeah I got it, and will consider it. They are both good ideas, and likely candidates for new functionality in later releases.
Thanks, Sindre :-)
