cartoonmonkey wrote:I have a sparkly new Nexus One here, and the Subsonic app for Android is amazing. I'll be donating for sure.
One other feature suggestion, in the black space on the main page, a nice customizable icon for which server you're using, or at least some text describing which server you're logged into. ( say 3g vs Home wifi ) -swish swipe to select the server.
C
alphawave7 wrote:Slighty OT, but I'm also using a Nexus One (GREAT PHONE!!)...does Subsonic pause/skip during the initial streaming/downloading for you, cartoonmonkey? The notification itself causes the pause/skip on my unit...very frustrating!
jm9843 wrote:I also experienced a different issue recently, but it's only happened once so I can't say for sure what happened. Someone else correct me if I'm wrong but I think that in the event of a SocketConnection timeout, the incomplete song will play until the end of what downloaded and stop playback. Only then will Subsonic attempt to download the entire song again and the incomplete song begins playback again from the beginning. To make matters worse, it only retries the download once the incomplete song is "active in the queue." The song may be way down the playlist and Subsonic could or should have retried/resumed the download well ahead of it actually playing. If it were to do so, the user wouldn't notice that any connection problems had occurred.
alphawave7 wrote:I get a skip first after a few seconds of playback, then again approx. 15-20 seconds later (I assume the first song has completed d/l'ing), than another skip (I assume as it continues to d/l the second song), despite the notification still saying the title of the first song. I get a minimum of three skips on the first song. Usually, the rest play back flawlessly, because they have all downloaded to the phone, but skips return upon adding to the playlist. I think it may be an Android issue on notifications, and not sure SubSonic can work around them?
jm9843 wrote:alphawave7 wrote:I get a skip first after a few seconds of playback, then again approx. 15-20 seconds later (I assume the first song has completed d/l'ing), than another skip (I assume as it continues to d/l the second song), despite the notification still saying the title of the first song. I get a minimum of three skips on the first song. Usually, the rest play back flawlessly, because they have all downloaded to the phone, but skips return upon adding to the playlist. I think it may be an Android issue on notifications, and not sure SubSonic can work around them?
That sounds almost identical to my experience. I seem to have two skips for the first song only and then the rest plays flawlessly as you say. I'm not sure about further adding to the playlist, I'll have to experiment with that.
I'm thinking that Sindre should be able to track this problem down as the skips only seem to occur by Subsonic notifications and not notifications from other programs (like email, twitter, etc.). Also, track changes after the first song cause a notification with the new song title and it does not create a stutter in playback. Perhaps it's an issue of priority when downloading, playback of the downloading track, and a Subsonic notification is all happening simultaneously?
