Subsonic init script change for RedHat - Fedora rpms
Postby vachaun22 » Mon Mar 15, 2010 12:48 pm
I'm submitting a request for a change to the fedora/redhat rpms installation.
Rather than have the startup options being changed in the subsonic init script where incorrect editing can have catastrophic effects on the service starting, I recommend altering the script in the following way:
-SUBSONIC_ARGS=""
+[ -r /etc/sysconfig/subsonic ] && . /etc/sysconfig/subsonic
Then add the following file:
# command line options for subsonic
# For example, to specify that Subsonic should use port 7070
# and use a Java memory heap size of 80 MB, use the following:
# SUBSONIC_ARGS="--port=7070 --max-memory=80"
SUBSONIC_ARGS=""
This allows all configurations options to be made in the same location, and prevents people from incorrectly editing the subsonic startup script.
vachaun22
Postby sindre_mehus » Tue Mar 16, 2010 8:32 am
Yes, I agree, that is much better. Will fix that in the next release.
Thanks a lot!
