Possibility of distro RPMs
Postby vachaun22 » Wed Apr 21, 2010 4:27 pm
Since distributions are inconsistent across their init scripts and whatnot, would it be possible to create distro specific rpms?
I have rewritten the init script included in the RPM to work with the init system of openSuSE 11.2:
#!/bin/bash
# subsonic      This shell script takes care of starting and stopping Subsonic
# chkconfig: - 80 20
### BEGIN INIT INFO
# Provides: subsonic
# Required-Start: $network $syslog
# Required-Stop: $network $syslog
# Default-Start:     2 3 4 5
# Default-Stop:      0 1 6
# Short-Description: Subsonic daemon
# Description:       Starts the Subsonic daemon. Subsonic is a web-based
#                    music streamer, jukebox and Podcast receiver.
#                    See http://subsonic.org for more details.
### END INIT INFO
# Author: Sindre Mehus <sindre@activeobjects.no>
# To change the startup parameters of Subsonic, modify the service
# configuration file /etc/sysconfig/subsonic rather than this file.
[ -r /etc/sysconfig/subsonic ] && . /etc/sysconfig/subsonic
PATH=/sbin:/usr/sbin:/bin:/usr/bin
DESC="Subsonic Daemon"
NAME=subsonic
PIDFILE=/var/run/$NAME.pid
LOCKFILE=/var/lock/subsys/$NAME
## Need to check for java bin in checkproc/killproc not subsonic
BIN=/usr/bin/java
DAEMON=/usr/bin/$NAME
DAEMON_ARGS="--pidfile=$PIDFILE $SUBSONIC_ARGS"
SCRIPTNAME=/etc/init.d/$NAME
## Source rc.status and reset status
. /etc/rc.status
rc_reset
# Check for missing binary
if [ ! -x ${DAEMON} ]; then
   echo -n >&2 "Subsonic daemon, ${DAEMON} is not installed. "
   rc_status -s
   exit 5
fi
# Function that starts the daemon/service
do_start()
    # Check if daemon is already running.
    checkproc -p ${PIDFILE} ${BIN}
    case $? in
   0) echo -n "- Warning: daemon already running. " ;;
   1) echo -n "- Warning: ${PIDFILE} exists. " ;;
    esac
    echo $"Starting $NAME ..."
    startproc -v -p ${PIDFILE} ${DAEMON} ${DAEMON_ARGS}
    rc_status -v
# Function that stops the daemon/service
do_stop()
    echo -n "Shutting down ${NAME} daemon "
    checkproc -p ${PIDFILE} ${BIN} || \
   echo -n " Warning: daemon not running. "
    killproc -p ${PIDFILE} -t 10 ${BIN}
    rc_status -v
case "$1" in
  start)
   do_start
  stop)
   do_stop
  status)
       echo -n "Checking for $NAME daemon "
       rc_status -v
  restart|force-reload)
   do_stop
   do_start
   echo "Usage: $SCRIPTNAME {start|stop|status|restart|force-reload}" >&2
   exit 3
esac
vachaun22
