[Android App] Better Bluetooth Support
Postby robotgeek » Fri Aug 20, 2010 2:52 pm
Currently, if subsonic does not grab audio focus (granted, this was froyo feature). To explain further, if subsonic is playing, and I use my bluetooth headset and hit the play/pause button, the last app that grabbed audiofocus will play. Expected result is for subsonic to pause playing.
Details of this Android 2.2 feature is here:
http://developer.android.com/reference/ ... tener.html
robotgeek
Postby sindre_mehus » Fri Aug 20, 2010 9:06 pm
Thanks for the tip. I want to be backward compatible with 1.5, but I'll see what I can do.
Postby vancamp » Sun Aug 22, 2010 3:31 am
Better bluetooth support is at the top of my wishlist. I'm always using BT headphones, so making the subsonic player on my android (Droid X) play properly along with the other music players is a big wish.
vancamp
Postby fredx21 » Mon Aug 23, 2010 5:48 pm
I just discovered subsonic. Great app!
I use BT headset everyday at work and having subsonic control from my headset buttons would make usage much better. Right now when I use my headset to pause/play the subsonic player, it launches the default Android player... not very convenient!
I am very pleased with the application overall. You can expect my donation soon.
fredx21
Postby fredx21 » Tue Aug 24, 2010 11:27 am
Thanks a bunch for the update with BT support! I really like subsonic and have been showing off since I got it. I'm about to become a satisfied detonator.
Thanks for all the efforts you put into this project.
fredx21
