Language settings for Linux version of Subsonic
Postby jrh.koenig » Fri Aug 27, 2010 2:42 am
Hi Sindre,
is it possible that you add LC setting to the start script for the linux version of subsonic? In the last time more and more people have problem that is no LC settings in your start script.
I know that en_US.UTF-8 supports german chars and should support french chars. I don't know if it support norwegian chars too. That have to tested.
Kind Regards
Johannes
jrh.koenig
Non ascii characters
Postby richfeat » Wed Sep 01, 2010 9:25 pm
A "fix" has been posted for handling of non-ascii characters in song names - it works for me too:
http://kevinmorey.com/post/967347977/fi ... characters
It describes the problem well.
A general fix for Subsonic would be good.
richfeat
Postby rgthorpe2001 » Sat Sep 11, 2010 2:24 am
Hurrah and thanks for the pointer to Kevin's posting -- I was concerned that I was going to have to manually rename all my classical files with French and German accents to get them recognized, and this fixed my problem with 30 seconds editing in nano.
UPDATE: If you applied in 4.0, you need to reapply the fix after upgrading to 4.1.
rgthorpe2001
Re: Non ascii characters
Postby dagnorland » Fri Oct 01, 2010 8:16 am
Super.. Fixed my norwegian issues too. Thanx.
dagnorland
Re: Language settings for Linux version of Subsonic
Postby smikisergi » Fri Nov 28, 2014 11:06 am
Can you please post the solution here? Kevin's post is no more online...
thanks
smikisergi
