[Android] Setting to keep screen on
Postby sigel » Mon Nov 08, 2010 8:54 pm
It's a pain when im driving and I have to do my unlock pattern before I can change a song...
Maybe have a setting when enabled keeps the screen on and maybe just dims down when inactive, but dosent go into the unlock screen.
sigel
Postby stennie » Mon Nov 08, 2010 9:08 pm
There are lots of apps and widgets that allow you to change your screen timeout settings easily. I personally recommend "Quick Settings" as it allows you to quickly change a whole host of settings from your drag-down bar.
It would be a nice feature to integrate into Subsonic, but as it probably won't happen soon, apps in the Market should tide you over.
stennie
Postby sigel » Mon Nov 08, 2010 9:56 pm
Thank you, quick settings will do the trick for now.
sigel
