[REQ] Google Chrome App
Postby mfalzon » Wed Dec 08, 2010 2:11 pm
I think it would be pretty cool if subsonic has a Google Chrome App. What do you guys think?
mfalzon
Postby evandena » Fri Dec 10, 2010 8:06 am
This would blow any music player out of the water.
evandena
Postby qbit » Fri Dec 10, 2010 5:19 pm
shouldn't be too hard to make the default web interface available : http://code.google.com/chrome/apps/docs ... .html#live
qbit
Postby qbit » Fri Dec 10, 2010 5:35 pm
Here is a quick manifest to use the USERNAME.subsonic.org interface.
http://qbit.devio.us/SubSonic.zip
Just unzip - open the manifest.json file and change USERNAME to what ever your .subsonic.org setting is set to :P ..
then in chrome type in "chrome:extensions" hit enter, then click the + by "Developer Mode"..
click "Load Unpacked extension", and navigate to the unzip'd folder containing the manifest file ..
it should load up into the list of extensions - and be listed in the app's area.
The icon is kinda crappy :P - if anyone has a better one - feel free to add it! :D
qbit
Postby qbit » Fri Dec 10, 2010 5:40 pm
as soon as i figure out a way to ask for usernames, and get a better icon - I will publish this to the web store.
qbit
Postby qbit » Fri Dec 10, 2010 7:05 pm
https://chrome.google.com/webstore/deta ... nifpealoki
Done! :D - it's not as cool as a full webapp - bit it's a start!
qbit
Postby Emergence » Mon Dec 13, 2010 6:26 am
Would people prefer a web app or just something that links them over to their server. Personally I would rather have a web app, and if anyone wants to help I do have a web app started for chrome. Just haven't had a chance to finish it.
Emergence
Postby alphawave7 » Mon Dec 13, 2010 8:03 am
Emergence wrote:Would people prefer a web app or just something that links them over to their server. Personally I would rather have a web app, and if anyone wants to help I do have a web app started for chrome. Just haven't had a chance to finish it.
Options are great! I can't help (not a dev) but I'll be a happy user once it's complete! 8)
Postby kermit22 » Mon Dec 13, 2010 2:39 pm
It would be nice for users without xxxxxx.subsonic.org addresses use this as well. Any chance of adding a custom address option?
kermit22
Postby mfalzon » Tue Dec 14, 2010 2:01 pm
Great Work!!
needs support for non subsonic.org subdomains :)
mfalzon
Postby qbit » Tue Dec 14, 2010 3:34 pm
Emergence - I would like to help out! Do you have the code on something like github.com?
kermit22 and mfalzon, I am planning on adding support for multiple servers, and non-subsonic.org urls.
Any other feature suggestions?
qbit
Postby hansolos » Tue Dec 14, 2010 10:46 pm
Depending on how you do the non subsonic url you might need the port.
hansolos
Postby qbit » Tue Dec 14, 2010 11:36 pm
yep.. port will be include-able
hansolos wrote:Depending on how you do the non subsonic url you might need the port.
qbit
Postby GJ51 » Tue Dec 14, 2010 11:59 pm
I just add bookmarks that appear accross the top to the sites I visit.
e.g.
http://music.stozher.com/login.view?use ... &password=
If you want to connect to a local site the format is the same.
192.168.1.254:8080/login.view?user=guest&password=guest
Clicking on the shortcut takes you right there without having to log in.
I've got seven active links and can change sites with one mouse click in an instant.
I use Chrome almost exclusively for SS playback. It handles internet radio streams much better than IE and it just looks cleaner.
Postby Emergence » Wed Dec 15, 2010 2:39 am
hmm I might be able to make the subTunes interface work
Emergence
