ability to rate songs
Postby trinitymusic » Thu Dec 09, 2010 11:13 pm
At the moment subsonic only allows you to rate the album, I think it would be a great benefit to be able to rate each song individually. Ideally put 5 stars next to each song before the "play" button. Also, the rating ability / stars should show up in the same manner when added to the playlist. This way you can add numerous songs to the playlist and then rate them as you are listening.
Let's face it, there are usually only 1 or 2 songs that are good from an album these days. The ability to rate by individual song would be much more useful.
-Mike
trinitymusic
Postby pred2k » Fri Dec 10, 2010 8:54 am
There is already a thread here but you are right, this is still missing!
pred2k
Postby aktiveradio » Fri Dec 10, 2010 4:16 pm
This would be great, and if it was a function in the API even better then you could do it from the APPs also.
aktiveradio
