[Solved] Ubuntu 10.10: /var/run/subsonic gone after reboot
Postby CarPro » Mon Dec 13, 2010 6:26 am
could you add following lines into your start script?
# create PID directory if not exist
[ -d /var/run/subsonic ] || install -m 755 -o subsonic -g subsonic -d /var/run/subsonic
It's because /var/run is a tmpfs filesystem and after reboot the subsonic subfolder is gone.
Best regards
CP
CarPro
Postby stozher » Mon Dec 13, 2010 11:00 am
Subsnic PID file is a created in "/var/run/" directory not in subdirectory. Default PID file is a "/var/run/subsonic.pid". See "/etc/init.d/subsonic":
NAME=subsonic
PIDFILE=/var/run/$NAME.pid
If you don't start SS as a daemon process define PID file in "/usr/share/subsonic/subsonic.sh". Open with plain text editor and edit line:
SUBSONIC_PIDFILE=
Variables in "/usr/share/subsonic/subsonic.sh" is a default values for non-daemon user startup. To change daemon variables edit "/etc/default/subsonic" (example from my server):
export LANG=en_US.utf8
SUBSONIC_ARGS="--home=/srv/subsonic --port=80 --max-memory=512 --default-music-folder=/srv/subsonic/Music --default-podcast-folder=/srv/subsonic/Music/Podcast --default-playlist-folder=/srv/subsonic/Playlists"
stozher
Postby CarPro » Mon Dec 13, 2010 2:48 pm
You're right. Sorry for posting too fast. :-(
I changed the script (to /var/run/subsonic/$NAME.pid) in the past, because I start the daemon as a non-root user.
And I was wondering , why there wasn't a /var/run/subsonic dir. everytime I rebooted.
Again, sorry.
best regards
CarPro
