:idea: Rhythmbox integration (plugin a la Last.fm)
Postby d3ngar » Fri Dec 17, 2010 4:05 pm
First up: I'm a very satisfied user and will probably donate a second time.
I would like to link the music straight into Rhythmbox to play it while I use the computer. I often close the web-browser and it's quite frustrating when it happens :)...
I assume that Last.fm is streaming music in a very similar fashion as Subsonic. Quite likely that the underlying platform is Java based too. Might be possible to get the code and just point it on a variable server, same API?
While DAAP would be a solution that doesn't exclude all those Windoze and Mac users, I think that quite a few of us users would be very happy to link it to Rhythmbox on other home computers and then to stream through Rhythmbox.
Bump your support for the idea - Thanks!
d3ngar
Re: :idea: Rhythmbox integration (plugin a la Last.fm)
Postby precipitous » Fri Dec 17, 2010 4:36 pm
d3ngar wrote:Hi,
I have often wished for such a feature in Banshee...
precipitous
Postby SteveW » Sat Sep 22, 2012 12:35 pm
I'm going to bump this for you and say that it'd be a fantastic idea!
I have the same problem, where I often want to close my web browser, and I don't want to load a 200GB music library using NFS over the network into Rhythmbox.
What I'd like to be able to do is to have a similar UbuntuOne-like addon in Rhythmbox and stream the songs over the network instead.
I'd try it myself if I wasn't so useless at figuring out where to get started!
SteveW
Postby hakko » Sat Sep 22, 2012 12:42 pm
Isn't this a good idea that's more likely to get implemented if posted on the Rhytmbox forum/mailing list/issue tracker/whatever?
MusicCabinet developer
hakko
Postby precipitous » Mon Sep 24, 2012 5:04 pm
SteveW wrote:I'm going to bump this for you and say that it'd be a fantastic idea!
I think this is a wonderful idea as well, except that I would want it for Banshee instead of Rhythmbox... In fact I would tackle it myself if it were not for the fact that I don't know how! Hopefully someone will be able to come up with something that could be dropped into either application without too much re-working...
precipitous
