button listing tracks cached locally on smartphone
Postby atlana » Sat Jan 15, 2011 1:28 am
I would like to see on the smartphones apps "home screen" an item that shows
"Locally Cached Songs/Videos"
and lists the music clips/movie clips that are locally offline-cached on the smartphone. Especially useful if you have set subsonic NOT to allow your smartphones OS to traverse and index subsonics' locally/offline cached songs.
Especially useful if you've allocated 5 GB for cache, and are inside some 'bunker-building' that has no WIFI and shields your cellular-signal off, so you've to rely on whats cached, and cant remember jack-squack what you played last ;)
atlana
Postby atlana » Mon Jan 17, 2011 3:16 pm
apparently there IS a sort of workaround, which is rather a bit hidden away. I stumbled over it by accident.
One has to go to the main-screen and select as "server"the OFFLINE option. then it'll just show the tracks that are cached in the cellular subsonic client.
cheers
atlana
