jeffdgr8 wrote:Thanks for the info. I think I hadn't enabled the transcode setting for the player before, missed that step. I also was using the default "Step 1" string that other video types use. Looks like the "-async 1" setting is the difference. It seems there is no way to select a start time on the player when transcoding VOB files though. But at least they're playing now. Thanks again for your help.
Ballernase wrote:hi, guys.
try this: - dont change your transcoding settings in subsonic
- rip your dvd to a single .vob-file.
- copy file to your subsonic video folder
- rename file from .vob to .mpg
enjoy
ffmpeg -ss %o -i %s -b %bk -s %wx%h -ar 44100 -ac 2 -v 0 -f flv -
Users browsing this forum: Google [Bot] and 9 guests
