Last.fm Scrobbling for mobile applications
Postby heynowsaywhat » Fri Feb 25, 2011 9:01 pm
I would love to be able to have Last.fm Scrobbling my on mobile device.
I have tried "Scrobble Droid" but it does not pick up any songs playing off of Subsonic
Thank you
heynowsaywhat
Postby disgustipated » Fri Feb 25, 2011 10:05 pm
yes, i would like to see some sort of scrobbling support outside of the server based when listening on android. i have simple last.fm scrobbler and it doesnt pick up the subsonic player
disgustipated
Postby disgustipated » Sat Feb 26, 2011 11:10 pm
to add to this the reason i dont like the scrobbling built in while listening over android is the entry is marked as "scrobbled" when the track downloads to the device, not as it is listened to in the android player
disgustipated
Postby nibato » Sun Feb 27, 2011 1:21 am
last.fm scrobbling is going to be in the next android release if i'm not mistaken. It's already on the svn.
http://subsonic.svn.sourceforge.net/vie ... ision=2184
nibato
Postby disgustipated » Mon Feb 28, 2011 3:28 pm
this looks great, ive been looking for the source, didnt know where to find it
I compiled it and installed it and the check box is indeed there, will have to dive into this a bit more to see how it all works. looks like im getting an I/O error when trying to play audio with the recent version of what i pulled from sourceforge
disgustipated
Postby bushman4 » Mon Feb 28, 2011 3:59 pm
Since a REST method was added with Version 4.4 for scrobbling, I believe that the android app will just issue that command (if online) to the server so that the server can scrobble the tracks you play as you play them (instead of as you download them as was done in the past.)
What I am most interested to see is how scrobbling is handled when the app is in "offline" mode (ie, is it queued and submitted when possible, or discarded?) and also to see if perhaps the same REST method will be used to populate the "Now Playing" user list, so you can see what a mobile user is ACTUALLY listening too, not what they are currently downloading.
Looking forward to the next version,
Glenn
Postby donjulien » Tue Mar 01, 2011 2:33 am
Looking forward, too.
donjulien
