Please add an android equalizer
Postby dbbarney » Mon Apr 18, 2011 6:56 am
Music thru my samsung galaxy is FLAT! An equalizer to be able to mess with the bass/mid/treble (and everything in between) would be perfect for the mobile apps like android.
dbbarney
Postby Alsaya » Mon Apr 18, 2011 10:30 am
As far as I know, there will be one in Gingerbread
Subsonic on Server 2012, only flac
Alsaya
Postby dbbarney » Mon Apr 18, 2011 12:19 pm
I'm not sure what Gingerbread means...Sorry!
dbbarney
Postby Alsaya » Mon Apr 18, 2011 3:44 pm
The next version of the Android OS 2.3
Alsaya
Postby JesterEE » Mon Apr 18, 2011 7:59 pm
I don't want to speak for Sindre, but I'm pretty sure without the supporting android operating system (2.3.3 a.k.a Gingerbread [GB]), this can not be implemented. If you have a rooted android phone with Gingerbread, you can use the DSP Manager to change the audio output equalization.
-JesterEE
JesterEE
Postby rschauer » Wed Apr 20, 2011 1:09 pm
Not sure about DSP Manager, but I believe I was using it when I was running a rooted Eclair-based ROM on my Droid. I don't think root access is required in general. PowerAMP has a fully functional 10-band equalizer; my phone is rooted (CM6, which is Froyo-based) , so I don't know for sure, but I'm fairly certain this feature doesn't require root. As far as I know, it should be possible to implement such functionality into any app, but I haven't done much research into that on the development side.
BTW, dbbarney: Android OS releases are named after various desserts, and are alphabetical. I.e., 2.1 = Eclair, 2.2 = Froyo, 2.3 = Gingerbread. Therefore, my experience using equalizer-equipped apps on Eclair and Froyo (older versions) indicates to me that Gingerbread is not a prerequisite.
EDIT: Messed up the URL tag
rschauer
