Insert DSP (Winamp) plugin just before streaming?
Postby DJC » Sat Apr 30, 2011 7:41 pm
Would it be possible to insert a DSP or VST plugin just before streaming?. I'm particulary interested in using stereotool, which is a multiband compressor - clipper - limiter, that achieves an excellent FM type of sound.
Thanks in advance.
Daniel
DJC
Postby Lozzy » Tue May 24, 2011 3:28 am
I too would like to use this
Lozzy
Postby 3R3 » Tue May 24, 2011 8:12 am
oh man, think about plugging "Sound Solution" winamp plugin into the streaming chain. The flexibility, ooohh *faints*
(Sound Solution, is a emulation of a multiband compressor/expander, stereo expander and so on. has presets for famous hardware devices like Optimod and Orban etc)
3R3
Postby DJC » Tue May 24, 2011 1:06 pm
After a lot of trying a managed to insert stereotool as a command line in the transcoding chain and it is working perfect. See this post if tou are interested http://forums.stereotool.com/viewtopic.php?f=4&t=3679
Stereotool is much like soundsolution, maybe better, and free. Give it a try, first in winamp or as a VST, cause it seems a bit difficult at the beggining. Start from a preset.
Meanwhile, I guess the insert function of any DSP or VST will have to wait, allthough it would be awesome to have the possibility to insert an effect chainer, like Acon's one.
DJC
Postby 3R3 » Tue May 24, 2011 9:21 pm
thanks for the tip, will try out stereotool out right now. SoundSolution on the command line? A dream come true :-D ...and free? *faints*
3R3
