Thing I Miss in Sub
Thing I Miss in Sub
Postby Schishu » Wed Aug 03, 2011 4:59 pm
I miss an integratetd FTP Server who everyone can login with his account and make some uploads .
Schishu
Postby BKKKPewsey » Wed Aug 03, 2011 6:32 pm
as in More: Select file to upload: Upload: :?
Postby supra92 » Mon Aug 08, 2011 11:48 pm
That made me chuckle there, pewsey :-)
Agreed that's pretty straightforward -- has always worked on my server. Maybe Schishu was wanting FTP specifically? Would be rather odd in this day/age, but who knows. Or perhaps the the ability for a user to upload an artist/album directly into that artist/album's spot in SS, as opposed to merely being dumped in the "Incoming" folder.
Schishu, can you clarify what you're needing? the More->Upload solution provided in the previous post works, so long as you don't mind moving it later from Incoming to its proper spot in the folder structure.
Supra92
supra92
Postby bushman4 » Tue Aug 09, 2011 12:46 pm
BTW, you can have an artist and album show up in the proper locations now... if you create a zip file of the music in the proper folder structure and tell it to upload to the root of your music share and unpack zip files, it unpacks right into the directory structure.
For example (I just did this myself):
  • On the client machine, create a folder called "Phish"
  • Create a folder inside that called "~Live Recordings"
  • Create a folder inside that called "2011"
  • Create a folder inside that called "2011-08-08 - LivePhish.com Release - Hollywood Bowl, Hollywood, CA"
  • Place the music files in that last folder
  • Create a new zip file and drag the original "Phish" folder into it. This should compress the entire folder structure as-is.
  • Upload that zip file to your music share's root and check the option to unpack zip files.
HTH,
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
