guest access without logon screen?
Postby doctorevil » Sun Aug 21, 2011 6:12 pm
Is it possible to configure subsonic so that when someone comes to the site they are automatically logged in as a guest user with guest permissions without having to go through the logon screen?
I'm currently using a jinzora based website, but I'm very impressed with how well subsonic works and I'm very interested in converting my site over to subsonic.
Jinzora does this by default, which is why I wanted to ask if anyone knew how to do this or if it could be added as a feature.
doctorevil
Re: guest access without logon screen?
Postby GJ51 » Sun Aug 21, 2011 6:47 pm
There are two ways you can effectively achieve the same result.
You can post a message on the logon page that tells viewer to use "guest" for the Username and Password, or you can just embed the guest username and password in a link to the site.
http://maplegrovepartners.subsonic.org/
http://maplegrovepartners.subsonic.org/ ... word=guest
The board truncated the link: login.view?user=guest&password=guest
is the last part.
Postby doctorevil » Sun Aug 21, 2011 9:01 pm
so there is no way to bypass the logon screen? bummer
guess I'll be staying with jinzora for now then.
doctorevil
Postby BKKKPewsey » Sun Aug 21, 2011 9:07 pm
If you had clicked on the link that GJ had kindly provided you would have seen that it does bypass the login screen :?
Postby doctorevil » Sun Aug 21, 2011 9:50 pm
BKKKPewsey wrote:If you had clicked on the link that GJ had kindly provided you would have seen that it does bypass the login screen :?
in order to get the same functionality that I have on jinzora it needs to go directly to the main index page on the site instead of the logon screen. without the ability to do that, it makes it hard for google to index the pages on my site. I want the site to be a public site.
doctorevil
Postby rastapi » Wed Aug 15, 2012 9:08 am
That is the exactly the functionality GJ has provided. Working for me.
4.7.beta3
Raspberry Pi (model b)
ARM1176JZF-S 700 MHz processor
256 mb RAM
Rasbian OS
100gb (and growing...)
rastapi
