Definition of a song played
Postby louischatillon » Fri Sep 09, 2011 12:29 pm
I was wondering if I was the only one that was thinking like this. My definition of a song played is when I listen to a song up until the end.
Right now a "song played" is if you started listening to it. That mean that if you are searching for a song and listen to the first 10 seconds of 46 songs, when you go back to the Tab "most Played" you will get those 46 songs that you really did not listen to the end.
I was wondering if there was a way of changing the definition so that a "Song Played" is when you listen to a song until the end.
louischatillon
Re: Definition of a song played
Postby BKKKPewsey » Sat Sep 10, 2011 5:26 pm
I think what you are asking would be difficult (if not impossible) in SS because you may be using an external media player,
so SS has no way of knowing how much of the song you listened to - only how much was streamed.
However there are some threads regarding a preview function in SS which would if implemented solve your problem.
Postby louischatillon » Tue Sep 13, 2011 1:54 pm
It's not what I wanted but I understand where your answer comes from ;)
I will just have to wait until/If preview is implemented.
Thanks for the answer.
louischatillon
