Wi-Fi streaming only
Postby louischatillon » Fri Sep 16, 2011 2:24 pm
Yesterday I was trying to listen to stuff using my Android phone over the 3G network but I could not make it work. I was getting an error message saying "Network not available'.
After several hours I saw the option "Wi-Fi streaming only" checked. I unchecked that and it stared to work.
Hoping it's not too much work, I was wondering if you could change the message from "Network not available" to something like "Wi-Fi streaming only"?
louischatillon
Re: Wi-Fi streaming only
Postby depthcore » Mon Oct 10, 2011 10:03 pm
I got exactly the same problem with my Galaxy S2. Additional I noticed if go into the subsonic menu from the Subsonic Widged on the Desktop I get the error message "network error". The only Way to solve this problem is to restart the phone and use subsonic without the widget.
@subsonic support
Do you need further information from us?
I hope you can fix this problem, because without the option "Wi-Fi Streaming only", subsonic is downloading every file while listening. I got over 4000 Musictracks, that would be bad for my SD card :)
depthcore
Postby BKKKPewsey » Mon Oct 10, 2011 11:12 pm
depthcore wrote:Hi,
So if the feature request above is implemented then that will solve all your problems :?
As I doubt this is the case then please repost in the correct forum section eg: HELP
and take a read of http://forum.subsonic.org/forum/viewtopic.php?f=2&t=5506 before hand.
@subsonic support
:shock: This is a user forum! and the answer is yes
