Android app: Select folder before retrieving contents
Postby murrayju » Fri Oct 14, 2011 12:56 pm
I have a problem with the current Android app that it will almost always timeout when retrieving the "All folders" content list. I have a very large library that is organized into multiple folders. I have found that if I disable a few folders, the app will then work just fine. I think that an improvement would be allowing one to select a folder in the app before retrieving the content. That way, I can get past the constant timeout errors.
Another improvement would be to not try to retrieve all of the content at once, and wait for the user to scroll down the list before getting more. Currently, the android app is completely unusable for me.
murrayju
