More stable LDAP Auth [Resolved]
Postby DaveWut » Thu Nov 24, 2011 12:29 am
Hi guys,
First of all, I would like to thanks the creator of this absolute beauty of life. The whole thing is absolutely wonderful and I wonder why it's not as popular as it should suppose to be. Anyway, here's my suggestion. In fact, this isn't a feature request, it's more like a stability request for a specific module in Subsonic. Right now, my network is configured with an Active Directory, which where all my users are authenticating. LDAP module seams to works perfectly, but some time, there's a little problem... even if I enter my correct username and password for a multiple time, the system said I couldn't log in, and then, at this point, I'm stuck to use the admin login (this is what I want to avoid).
Some time, I just look at my system (a x64 11.10 ubuntu server) and the system seams to be saturated. In this case, if someone tries to login, the system will say to the user he can't be authenticated. I was wondering if it was possible to add a sort of password caching for all LDAP authenticated users? In that case, if the server can't temporary reach the Active Directory for any authentication, Subsonic will use his cached password to authenticate the user.
So, how do you find the idea? Please let me know!
Dave
DaveWut
Re: More stable LDAP Auth
Postby DaveWut » Tue Jan 03, 2012 8:00 am
LDAP authentication is really unstable. I need to make an authentication through another service with my LDAP account, reconnect with the admin account on subsonic THEN connect with the LDAP account prior to successfully connect.
DaveWut
Postby DaveWut » Wed Jan 11, 2012 2:38 pm
Ok hey, let's give an another shot to this dead thread.
Here's the detailed log error :
[2012-01-11 09:08:30,268] INFO SubsonicLdapBindAuthenticator - Failed to authenticate user 'Dave' in LDAP.
org.acegisecurity.ldap.LdapDataAccessException: Unable to connect to LDAP server; nested exception is javax.naming.CommunicationException: windowsldap.local:389 [Root exception is java.net.NoRouteToHostException: No route to host]
        at org.acegisecurity.ldap.DefaultInitialDirContextFactory.connect(DefaultInitialDirContextFactory.java:189)
        at org.acegisecurity.ldap.DefaultInitialDirContextFactory.newInitialDirContext(DefaultInitialDirContextFactory.java:261)
        at org.acegisecurity.ldap.DefaultInitialDirContextFactory.newInitialDirContext(DefaultInitialDirContextFactory.java:241)
        at org.acegisecurity.ldap.LdapTemplate.execute(LdapTemplate.java:123)
        at org.acegisecurity.ldap.LdapTemplate.searchForSingleEntry(LdapTemplate.java:246)
        at org.acegisecurity.ldap.search.FilterBasedLdapUserSearch.searchForUser(FilterBasedLdapUserSearch.java:119)
        at org.acegisecurity.providers.ldap.authenticator.BindAuthenticator.authenticate(BindAuthenticator.java:71)
        at net.sourceforge.subsonic.ldap.SubsonicLdapBindAuthenticator.authenticate(SubsonicLdapBindAuthenticator.java:72)
        at org.acegisecurity.providers.ldap.LdapAuthenticationProvider.retrieveUser(LdapAuthenticationProvider.java:233)
        at org.acegisecurity.providers.dao.AbstractUserDetailsAuthenticationProvider.authenticate(AbstractUserDetailsAuthenticationProvider.java:119)
        at org.acegisecurity.providers.ProviderManager.doAuthentication(ProviderManager.java:195)
        at org.acegisecurity.AbstractAuthenticationManager.authenticate(AbstractAuthenticationManager.java:45)
        at org.acegisecurity.ui.webapp.AuthenticationProcessingFilter.attemptAuthentication(AuthenticationProcessingFilter.java:71)
        at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:252)
        at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:844)
        at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:644)
        at org.mortbay.jetty.bio.SocketConnector$Connection.run(SocketConnector.java:227)
        at org.mortbay.jetty.security.SslSocketConnector$SslConnection.run(SslSocketConnector.java:626)
Caused by: javax.naming.CommunicationException: windowsldap.local:389 [Root exception is java.net.NoRouteToHostException: No route to host]
        at com.sun.jndi.ldap.Connection.<init>(Connection.java:223)
        at com.sun.jndi.ldap.LdapClient.<init>(LdapClient.java:136)
        at com.sun.jndi.ldap.LdapClientFactory.createPooledConnection(LdapClientFactory.java:64)
        at com.sun.jndi.ldap.pool.Connections.<init>(Connections.java:115)
        at com.sun.jndi.ldap.pool.Pool.getPooledConnection(Pool.java:132)
        at com.sun.jndi.ldap.LdapPoolManager.getLdapClient(LdapPoolManager.java:328)
        at com.sun.jndi.ldap.LdapClient.getInstance(LdapClient.java:1590)
        at com.sun.jndi.ldap.LdapCtx.connect(LdapCtx.java:2643)
        at com.sun.jndi.ldap.LdapCtx.<init>(LdapCtx.java:306)
        at com.sun.jndi.ldap.LdapCtxFactory.getUsingURL(LdapCtxFactory.java:193)
        at com.sun.jndi.ldap.LdapCtxFactory.getUsingURLs(LdapCtxFactory.java:211)
        at com.sun.jndi.ldap.LdapCtxFactory.getLdapCtxInstance(LdapCtxFactory.java:154)
        at com.sun.jndi.ldap.LdapCtxFactory.getInitialContext(LdapCtxFactory.java:84)
        at javax.naming.spi.NamingManager.getInitialContext(NamingManager.java:684)
        at javax.naming.InitialContext.getDefaultInitCtx(InitialContext.java:305)
        at javax.naming.InitialContext.init(InitialContext.java:240)
        at javax.naming.InitialContext.<init>(InitialContext.java:214)
        at javax.naming.directory.InitialDirContext.<init>(InitialDirContext.java:99)
        at org.acegisecurity.ldap.DefaultInitialDirContextFactory.connect(DefaultInitialDirContextFactory.java:180)
        ... 42 more
Caused by: java.net.NoRouteToHostException: No route to host
        at java.net.PlainSocketImpl.socketConnect(Native Method)
        at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:327)
        at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:193)
        at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:180)
        at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:384)
        at java.net.Socket.connect(Socket.java:546)
        at java.net.Socket.connect(Socket.java:495)
        at java.net.Socket.<init>(Socket.java:392)
        at java.net.Socket.<init>(Socket.java:206)
        at com.sun.jndi.ldap.Connection.createSocket(Connection.java:365)
        at com.sun.jndi.ldap.Connection.<init>(Connection.java:200)
        ... 60 more
And then, when subsonic wants to authenticate me :
[2012-01-11 09:14:15,750] INFO SubsonicLdapBindAuthenticator - User 'Dave' successfully authenticated in LDAP. DN: CN=DaveWut,cn=Users,dc=windowsldap,dc=local
Please, at least one person should had encounter this kind of problem with a windows ldap server. Can you help me figure what's the problem?
DaveWut
Postby bushman4 » Wed Jan 11, 2012 2:55 pm
Looks like the root problem is:
Is your LDAP server really named windowsldap.local? If so, is that name resolvable to the correct IP address?
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby DaveWut » Thu Jan 12, 2012 3:07 pm
Pinging windowsldap.local into my local network works and return the right IP address. I can connect on it using AD Explorer from Microsoft by example. My SVN works too, I do not have any problems connecting each time with my AD credentials. Can I provide any information that could help you?
DaveWut
Postby Citlali » Thu Jan 12, 2012 7:16 pm
Perhaps you have port 389 blocked? I've been using LDAP authentication since 4.6 and haven't had any issues.
Citlali
Postby DaveWut » Fri Jan 13, 2012 1:31 pm
So I checked if the port was block on my server running WS 2008 R2 and everything was ok. I made some other test, I tried another LDAP client like LDAP Administrator 2012.1 and I was successfully able to connect on the server through port 389. LDAPS protocol is blocked though. Can I provide any other information?
Dave
DaveWut
Postby bushman4 » Fri Jan 13, 2012 3:21 pm
Try changing the LDAP host name to an IP address... does that work?
Glenn
Glenn Sullivan
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby Citlali » Fri Jan 13, 2012 7:31 pm
On the 2008 R2 server, do you get an errors in your audit logs from a login failure?
Citlali
Postby DaveWut » Mon Jan 16, 2012 2:03 pm
bushman4 wrote:Try changing the LDAP host name to an IP address... does that work?
Glenn
Hmm good idea, I'll try this right away and I'll give you feedback.
Citlali wrote:On the 2008 R2 server, do you get an errors in your audit logs from a login failure?
I do not have any error log about fail binds to the LDAP. However, I do have a warning log that specify I do have unsecured LDAP binds to the server, but this is expected, because I don't use a secure authentication method (and I should).
DaveWut
Postby Citlali » Mon Jan 16, 2012 5:44 pm
You might want to run rsop.msc and ensure there aren't any GPO's that have enabled signing requirements.
Citlali
Postby DaveWut » Tue Jan 17, 2012 2:34 pm
There's no signing requirements. The solution of Bushman4 seams to work. I'll keep you updated!
DaveWut
Postby DaveWut » Fri Jan 20, 2012 1:45 pm
As I said, I told you I would keep you updated about the situation and here I am. Since I changed LDAP URL to it's proper IP address, no problems occurred. I found that thing quite strange though, because every services I use are connected using DNS binds. Anyway, thanks for your help guys! Problem solved!
Dave
DaveWut
