Transcode iso
Transcode iso
Postby hendrick2488 » Thu Dec 08, 2011 12:04 am
I would like the ability to transcode an iso movie file so it can be streamed online.
I'm unable to find a way to do this so far.
Please and thank you.
hendrick2488
Re: Transcode iso
Postby masterofrpm » Thu Dec 15, 2011 11:21 pm
You will need to modify which player is used in order to use the ISO if you are planning on using the menus and special features of the DVD.
If you do not intend to use the menus nor special features then you would have to create a script/mod of some sort to detect the VOB files that contain the main presentation or the actual movie. Once it detects the movies VOB files you would have to string them together then transcode them to FLV format before sending to the player.
An easier way to do that is get a free DVD to FLV transcoder and encode all of the iso files that you intend to watch and put THOSE files in your Subsonic directory.
masterofrpm
Re: Transcode iso
Postby pettergulbra » Tue Mar 20, 2012 9:45 pm
Hi
Is an old thread, but I try what so ever.
I know that f.eks. VLC can open iso files.
How do I specify this, so I can stream the iso files?
Kindly
Petter
pettergulbra
Re: Transcode iso
Postby GJ51 » Wed Mar 21, 2012 7:07 am
