Use of Android 4.0 lock screen control api
Postby beyondinferno » Tue Dec 20, 2011 5:30 am
Google music uses it beautifully! Please add this feature.
Sent from my Galaxy Nexus using Tapatalk
beyondinferno
Re: Use of Android 4.0 lock screen control api
Postby NLclothing » Wed Mar 21, 2012 4:04 am
Bump for this please! Maybe even a mod??
NLclothing
Postby thirteen113 » Wed Apr 11, 2012 5:43 am
I also would appreciate this.
thirteen113
Postby irishgond » Sun Apr 22, 2012 7:37 pm
Yes, please add this
irishgond
Postby NLclothing » Mon Apr 23, 2012 11:57 pm
I too would like to see this.
The subsonic android app is getting disappointingly little attention the past 5 months, especially considering google's release of ICS as well as the style guide. There are quite a few features subsonic should be taking advantage of that it isn't, this being one of them.
I love the app, but if it isn't going to be getting the attention it deserves, perhaps sindre should consider working with someone that will push the necessary updates to subsonic if he would like to focus on the server side of things..
This is essentially a plea for updates, please please update the subsonic app!
NLclothing
Postby wjoe » Fri Apr 27, 2012 2:48 pm
Came here to suggest both of these things (Lock screen controls and ICS UI update). The app is mostly perfect, but having upgraded to an ICS phone and seeing other apps taking advantage of the lockscreen controls makes me wish Subsonic had them. It would also be nice to have an integrated menu button, with the menu button being deprecated as of 4.0.
Knowing Subsonic is GPL, I was thinking of taking a look at the source and trying to add it myself, but I guess the GPL only applies to the server, and not the app. Not entirely sure why, I guess it's something to do with the app usage requiring a licensed server, but the app itself is free on the Play store. It's a shame that it hasn't been updated in quite a while now, I would be interested in contributing to it since it's one of my most used apps.
wjoe
Postby bushman4 » Fri Apr 27, 2012 3:22 pm
The android source code is available... I don't know where offhand, but it is available out there.
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby NLclothing » Fri Apr 27, 2012 10:46 pm
wjoe, if you do end up doing some work to add these features, would you consider including the widget made here:
viewtopic.php?f=8&t=8963
I'm running this build and it works just fine, the original subsonic widget is just kind of ugly :/
NLclothing
Postby wjoe » Mon Apr 30, 2012 3:44 pm
There's no way to change the design of the lockscreen controls using the API, as far as I know - it just uses the system theme, so on stock ICS it'll look like stock ICS, and on a HTC phone with Sense it looks like Sense. Anything beyond that sounds pretty difficult, and a bit of a hack (see anything that used lockscreen controls pre-ICS, like WinAmp).
I have found the source code now (wasn't on the main Sourceforge page, but is within the SVN pages), so I'll look into this when I get the chance.
Edit: Looks like someone else has already made some changes to use the ICS style, and added the menu button here - viewtopic.php?f=5&t=8497&start=105 but it's also gone quiet. Might try and add the lockscreen controls to this source instead, though I don't want to fragment things too much.
wjoe
