server name should be flexible
Postby piethein » Wed Jan 25, 2012 10:28 am
When sharing media via a url subsonic assigns the url http://yourname.subsonic.org/share/[xyz].
yourname.subsonic.org is the name assigned in the 'Network'-'Access your server over the Internet using an easy-to-remember address.'-setting. I believe this should be more flexible. I use my own (sub)domain name for my subsonic server, but I cannot set it in the settings and have to manually edit the sharing links to get them to work.
I suppose it would not be too hard to make the assigned server name more flexible.
piethein
Re: server name should be flexible
Postby ytechie » Wed Jan 25, 2012 2:50 pm
Check out viewtopic.php?f=2&t=8612#p35500.
This has been asked for many times, and is on Sindre's TODO list.
Hope this helps!
ytechie
Postby piethein » Wed Jan 25, 2012 11:01 pm
Thanks, I have been looking/searching for the question in the forum, as I assumed it must have been asked before, but apparently my search was not smart/thorrough enough...
piethein
Postby piethein » Fri Aug 03, 2012 6:33 pm
I have just installed 4.7beta3, still addresses are in the form [subdomain].subsonic.org, would be great if that could be changed by default for 4.7! (see viewtopic.php?f=3&t=7507 and as posted above viewtopic.php?f=2&t=8612#p35500 as well)
piethein
