Web Player - Playlist Reorder & Resize
Postby partizan92 » Fri Jan 27, 2012 9:01 pm
I think that the playlist reordering needs to be updated on the web player to something a little more modern. Clicking the up arrow and waiting for the page to postback is time-consuming and tedious for large playlists. Here are some examples:
http://www.asp.net/ajaxLibrary/AjaxCont ... rList.aspx
http://jqueryui.com/demos/sortable/
Also, I would like to be able to expand the size of the playlist window or have a dedicated large playlist viewer so I can see more than 10 songs at once. I, unfortunately, can't go the route of an external player because I usually listen at work and don't want to install additional applications on my PC.
partizan92
Re: Web Player - Playlist Reorder & Resize
Postby ocknoz » Sat Jan 28, 2012 10:54 pm
just donated and thought i'd check the forum if this has been suggested already.
it has, so +1 for resizing and reordering the playlist.
other than that keep up the great work!
ocknoz
Postby ytechie » Sat Jan 28, 2012 11:19 pm
I thought of a way to reorder the playlist using drag and drop, but it would require a playlist callback for every row that an entry is moved.
ytechie
Postby mcnater » Tue Mar 13, 2012 4:12 pm
I would also love to see this. The playlist window is just too small currently.
mcnater
