Postby smidley » Mon Jan 30, 2012 11:21 pm
Right when when you tell subsonic to download album art, it gets saved as cover.jpg. I would like an option to define the file name of the file that gets saved. I want mine to be folder.jpg since I use other programs that will utilize this music also. Things like XBMC look for folder.jpg, along with other common programs.
smidley
Re: Album art downloaded to folder.jpg
Postby ianimacleod » Mon Apr 02, 2012 1:57 pm
I would like to elaborate on this request, since it is also XBMC related. I would like to allow an option where you can define the album art preference, for example; some of my albums have embedded art, folder.jg, and cdArt.jpg. For some reason cdArt.jpg is always chose, which looks strange.
I would like to be able to define the priority, or possible exclusion.
1. Embedded
Ignore cdArt.jpg may achieve what I want in the end.
ianimacleod
Postby BKKKPewsey » Mon Apr 02, 2012 2:36 pm
With regard to the folder.jpg - have you added the mask "folder.jpg" to the cover art settings in settings/general?
Postby ianimacleod » Mon Apr 02, 2012 2:52 pm
Yeah, it is there by default. can I do -cdArt.jpg to ignore cdArt.jpg?
ianimacleod
Postby ianimacleod » Mon Apr 02, 2012 3:38 pm
I even tried to remove all extenations, so it would be cover.jpg and folder.jpg only, but it still picks up cdart.jpg over the embedded artwork.
ianimacleod
Postby ytechie » Tue Apr 03, 2012 3:56 am
It sounds like Subsonic is choosing the art alphabetically.
ytechie
Postby bushman4 » Tue Apr 03, 2012 12:06 pm
I believe Subsonic uses image files in the same directory before it checks to see if there is embedded cover art.
It would be nice to be able to add "<embedded>" or something to the list of file names in the Cover Art mask setting to be able to control when the embedded art is checked. But currently it is not possible.
HTH,
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby Freddan101 » Sat Apr 14, 2012 8:46 pm
As the first poster asks, is there a way to get Subsonic to name downloaded covert art to folder.jpg instead of cover.jpg? Sonos doesn't play nice with cover.jpg files...
Freddan101
Postby BKKKPewsey » Sat Apr 14, 2012 11:30 pm
Simple answer is no (without modding) but has been requested (by me as well as others)
Postby Freddan101 » Sun Apr 15, 2012 7:52 am
BKKKPewsey wrote:Simple answer is no (without modding) but has been requested (by me as well as others)
Ok, thanks! I hope we'll see this implememted in the future.
Is it a pain to mod yourself?
Freddan101
Postby BKKKPewsey » Sun Apr 15, 2012 12:25 pm
I haven't seen any mods to change that so it may be hard coded into SS (which will mean a rebuild).
I just let SS download and then change the file name to folder.xxx - inconvenient but not too much of a problem.
Postby Freddan101 » Sun Apr 15, 2012 1:09 pm
BKKKPewsey wrote:I haven't seen any mods to change that so it may be hard coded into SS (which will mean a rebuild).
Nope, that's what I have to do as well then. I will probably run som simple batch appl to rename all existing files.
Freddan101
Postby flippedcracker » Wed May 02, 2012 4:04 am
I would like this option as well.
flippedcracker
Postby 3R3 » Fri Mar 01, 2013 12:10 pm
*necroing old thread since feature is not implemented yet*
I would like to choose where downloaded album art goes as well. Either a file location or a ID3 tag would be fine. And a means to choose or priorize embedded album art in the settings mask would be a good companion feature.
3R3
