Do not return to "Now Playing" folder when browsing
Postby Globe199 » Thu Feb 02, 2012 3:48 pm
I would like Subsonic to NOT return to the "Now Playing" folder when I'm browsing around. If I browse around but don't play anything, it will return after a short time. This is annoying.
I can always go to the folder if necessary by clicking on the album in the "Now Playing" frame on the right of the screen. Thanks.
Globe199
Re: Do not return to "Now Playing" folder when browsing
Postby Beowolf » Thu Feb 02, 2012 4:11 pm
actually may i ask a question, when i started i found this would take forever upto 2-5 mins, well i installed the latest java and flash on my server and afterwards it worked alot faster
I am only using a HP media server with 2gb ram, and i give 512 to Subsonic.
1,959 artists
1,970 albums
13,978 songs
941.65 GB (~ 14,628 hours)
Beowolf
Postby bushman4 » Fri Feb 03, 2012 2:04 pm
BTW, I have a workaround for the original poster's issue...
Right click in the "Now Playing" pane and choose "Back." It dumps you right back to where you were browsing from...
HTH,
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby ytechie » Fri Feb 03, 2012 8:04 pm
Check this out: Change redirect time in main.jsp - viewtopic.php?f=3&t=8492#p34937.
Hope this helps! :D
ytechie
Postby RevMen » Fri Feb 03, 2012 9:12 pm
This feature annoys me as well.
RevMen
