Android - Beats Support
Postby mjones73 » Tue Feb 14, 2012 4:50 pm
This is a low priority request but can the functionality be added to enable Beats support on HTC phones? It looks like Poweramp was just updated to support it so 3rd party players should be able to turn it on.
Matt
mjones73
Re: Android - Beats Support
Postby mikes » Wed Feb 15, 2012 12:03 am
You want sound defects?
mikes
Postby mjones73 » Wed Feb 15, 2012 3:55 am
Please tell me how it introduces defects in music playback...
Matt
mjones73
Postby mikes » Wed Feb 15, 2012 3:16 pm
By changing the sound from that which was recorded, obviously. Beats is just a glorified equalizer, probably best used to offset failings in the Beats headphones. Just get some decent headphones and avoid the equalization if you want good sound. Unless you do want sound defects, like turning up the thumping bass to try and blow the windows out of your car and impress the kiddies, that is.
mikes
Re: Re: Android - Beats Support
Postby paulodell » Wed Feb 15, 2012 3:36 pm
mikes wrote:By changing the sound from that which was recorded, obviously. Beats is just a glorified equalizer, probably best used to offset failings in the Beats headphones. Just get some decent headphones and avoid the equalization if you want good sound. Unless you do want sound defects, like turning up the thumping bass to try and blow the windows out of your car and impress the kiddies, that is.
Calm down dear
SubWiji http://tinyurl.com/7sxwbfv Install http://subwiji.paulodell.co.uk
Transcode Step1 "ffmpeg -f mp3 -i %s -ab %bk -v 0 -f mp3 -"
Tremor Games http://www.tremorgames.com/?ref=59174
paulodell
Postby dethknite » Thu Jun 28, 2012 6:20 pm
I would love to see this supported in the next android release. Currently I am running an ICS port on my android and love subsonic. I can only get one DSP working, but I love the AwesomeBEATS generic port. Problem is it doesn't seem to work with Subsonic, but works great with other audio players.
dethknite
