offline subsonic library access
Postby ayperos » Sat Apr 28, 2012 4:45 pm
Hi again,
I've got another request.
I'd like to use subsonic client (android phone) without any internet access, just like a simple media player.
With no internet connection, subsonic client can't load the folders tree, waiting for synchronization with the server. Then in offline mode, I have to switch to another player.
My recommendations is to cache the previous loaded tree when subsonic client is not able to synchronize with the server.
Thanks to you.
ayperos
Re: offline subsonic library access
Postby bushman4 » Mon Apr 30, 2012 2:51 pm
When a data connection is not available, go to the home screen in the android app and in the "Select Server" box, choose "Offline."
Then the "Media Library" button will show you a limited media library of only content that is in your phone's subsonic cache and available offline.
Hope this helps,
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby sterlingphoenix » Sun May 06, 2012 7:13 am
I came to this forum specifically to ask this question, and found an answer (: Thanks!
I do, however, think it would be nice if Subsonic could cache playlists, too. To be honest, 85% of the time I use Subsonic to listen to the same six playlists, all of which I have cached. If offline mode cached playlists, too, I'd be able to use Subsonic in offline almost always. Yeah, that'd only save a couple of seconds, but hey (:
Either way I'm glad to know an offline mode does exist since I'm going to be on a long flight soon.
sterlingphoenix
