Sleeptimer
Sleeptimer
Postby Jabba-deHut » Thu May 31, 2012 4:38 pm
I hope you can implement an easy sleeptimer. so subsunic will not run the complet night when i go to bed and list a short time...
I hope a timer is so easy as i think. :-)
Jabba-deHut
Re: Sleeptimer
Postby bushman4 » Thu May 31, 2012 5:18 pm
What operating system?
On Linux, you could use Cron to stop and restart the service in the morning.
On Windows, a Schedule Task would work.
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Re: Sleeptimer
Postby Jabba-deHut » Thu May 31, 2012 6:29 pm
I mean the Android Client.
My Server is running 24/7, but the Battery from Mobilephone is empty when it runs over the night. :(
Jabba-deHut
Re: Sleeptimer
Postby bushman4 » Thu May 31, 2012 6:40 pm
I not sure I understand what you want to do... if you want to limit the amount of time the Android Client stays playing after you fall asleep, only put a few items in your playlist...
Glenn
Glenn Sullivan
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Re: Sleeptimer
Postby GJ51 » Thu May 31, 2012 7:18 pm
Wht not just plug in the phone?
Re: Sleeptimer
Postby Jabba-deHut » Thu May 31, 2012 7:22 pm
Because I listen Audiobooks and it's not nicely I wake up and my audiobook is over and I have no Idea where I sleepd in. ;)
Jabba-deHut
Re: Sleeptimer
Postby bushman4 » Thu May 31, 2012 7:26 pm
OK, well if you are looking for some built in functionality to turn off Subsonic after a certain amount of time, it does not exist.
There are other applications that may be able to do it... my phone has a feature called "Smart Actions" that could probably do it.
Glenn
Glenn Sullivan
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Re: Sleeptimer
Postby Jabba-deHut » Thu May 31, 2012 8:02 pm
Thanks, but my Mobile has no feature like this and "Smart Actions" is not avilable, too. :(
Jabba-deHut
Re: Sleeptimer
Postby MoreTrife » Tue Apr 16, 2013 2:01 am
there is an app called "music sleep timer".
it is kind of brute force. but it works.
i was actually logging on to see if subsonic has a timer in the android client but it looks like it doesn't.
and i don't just add a few songs because i have a big playlist that i shuffle.
MoreTrife
