Fix for xxxxxx.subsonic.org redirect?
Postby gurutech » Mon Jun 18, 2012 1:06 am
I seem to be having a problem with the Subsonic redirect. It works fine if I am on my home network, but as soon as I try to access through either iSub, or from a computer not on my home network, I cannot connect. I have my own personal redirect through "No-IP", and that works fine, either on or off my home network.
I've traced the problem to what seems to me the Subsonic redirect uses the actual "private" IP address of my SS server, and not my "public" IP address at port 4040.
So if I use "myhost.subsonic.org", I am routed to my 192.168.x.x IP address, which of course won't work externally due to the nature of IP, but if I use "myhost.no-ip.com", it routes to my public IP address, which works anywhere.
Is there any way to configure Subsonic to use the external IP address instead of the internal one?
gurutech
Re: Fix for xxxxxx.subsonic.org redirect?
Postby BKKKPewsey » Mon Jun 18, 2012 2:54 am
I am assuming you did read the rest of the posts here
Postby gurutech » Mon Jun 18, 2012 3:42 am
Yes, but my problem is that everything works fine internally, but not externally - but only if I use the xxxx.subsonic.org address. If I use my no-ip.com address, everything works fine.
I tried pinging my subsonic address, and it resolves to one of the .subsonic.org addresses 66.49.215.227, but then gets forwarded to my INTERNAL 192.168.x.x IP address on port 4040. It should be forwarding to my PUBLIC IP address (which as a moderator, I'm sure you can see).
gurutech
Postby alphawave7 » Mon Jun 18, 2012 3:48 am
gurutech wrote:Yes, but my problem is that everything works fine internally, but not externally - but only if I use the xxxx.subsonic.org address. If I use my no-ip.com address, everything works fine.
I'm at a login for Buster Music Center...seems to be working!
Postby gurutech » Mon Jun 18, 2012 1:08 pm
Did you enter my public IP address directly or my xxxxx.subsonic.org URL?
gurutech
Postby alphawave7 » Mon Jun 18, 2012 6:55 pm
gurutech wrote:Did you enter my public IP address directly or my xxxxx.subsonic.org URL?
IP:4040. PM me your SS.org name. :)
