Customized Subdomain/Domain upon approval
Postby azkreationz » Tue Jul 24, 2012 6:54 pm
Sindre, I know this has probably been discussed somewhere already, but I did a search and found nothing... so here's my request :)
I'd like to be able to customize the subdomain/domain entry for the server so it lets you, upon approval [donation], choose what you would like to use as your domain/subdomain.
maybe allowing a choice between the subsonic subdomain and your own domain?
I personally am using my own domain at the moment - and would like the share feature to work correctly without it telling me the subdomain function isn't set up correctly.
I'm currently using 4.7.beta2 (build 3012) – June 9, 2012
This would definitely be a well-received feature I'm sure!
Thanks for all the hard work on this - love subsonic.
azkreationz
Re: Customized Subdomain/Domain upon approval
Postby seb_lau » Wed Aug 15, 2012 11:33 am
Ditto this, I use ARR [application request routing in reverse proxy mode] to mask my actual subsonic location and would rather the share functionality point to my customised URI than the "real" one.. (Plus it means I have to expose an extra port that is not on ssl)
https://www.mydomain.com/music/ (ARR internally routes to) http://myip:81/music/ (note ARR also adds my own SSL which is bypassed by the share link as well as needing the extra port)
seb_lau
