Alsaya wrote:But only for folders one level down, I've multicd albums in a cd per folder under a folder named for the album and got no year, even I have it in the name of the folder.
PieterB wrote:I just added comments to a an album. Of course saved the comment. Then I edited the tags. A minor edit, I changed the year. And my carefully crafted text had disappeared! To be sure, I repeated the sequence, and YES the comment disappeared again.
That IS a bug.
PB
but some abuse the privilege!Nebol wrote:
Also, a common thing must be to rename a song in the filesystem. Meaning you have to re-scan all of the 13k songs...
AND you have to clean the entire database to remove the old incorrectly named file.
It would be useful to have the option of re-scanning just a certain folder.
It would also be useful to do the cleaning at the same time you scan. That way you just have to access the disk ONCE.
Scan the folder into a tree, compare against old info & clean, then add new songs. One operation (for the user) instead of two.
Hmm also, is the internal DB slow? Would be nice having the option to use an existing database server instead.
