Subsonic 4.0.beta1 released
Postby SpritHansi » Sat Apr 24, 2010 1:27 pm
I can't get the chat to work in v4 beta 1. Yes, it's enabled in settings :-)
Regards
SpritHansi
SpritHansi
Postby cellulit » Sat Apr 24, 2010 5:05 pm
hey... does "new tagging library" mean no support for musepack?
thx.
.cell
cellulit
Postby tacgnol » Sat Apr 24, 2010 9:47 pm
Sweet, it looks like my Monochrome themes made it into 4.0!
tacgnol
Can't update tags on .m4a
Postby adhesiv » Sun Apr 25, 2010 8:38 am
When trying to update tags on .m4a files i get the following error:
"Tag editing of .m4a files is not supported."
adhesiv
album art within artist view
Postby adhesiv » Sun Apr 25, 2010 8:47 am
Is there a reason the album art within an artists view is not lined up for a uniform look? On the Home screen the album art is perfectly lined up and looks great but the view linear placement gets messed up on the artists page.
adhesiv
Postby donpearson » Mon Apr 26, 2010 10:04 pm
im running subsonic on port 85 and it dont seem to be working since iv installed the new beta.
Have i missed some thing ?
Facebook Group:
donpearson
Postby precipitous » Tue Apr 27, 2010 6:08 am
donpearson wrote:im running subsonic on port 85 and it dont seem to be working since iv installed the new beta.
4.0 Beta (at least in my experience) defaults to running on port 4040...
precipitous
Postby utopian » Tue Apr 27, 2010 9:22 am
i had mine running on port 8090 and the new version retained the port info...
utopian
Postby precipitous » Tue Apr 27, 2010 2:11 pm
utopian wrote:i had mine running on port 8090 and the new version retained the port info...
After doing some further investigating I found that Subsonic is not recognizing my router as one that supports UPnP (even though it does). Perhaps this has something to do with why my original setup using port 8080 was not carried over to version 4.0 Beta?
I am curious to know what other users have experienced...
precipitous
Re: Can't update tags on .m4a
Postby sindre_mehus » Tue Apr 27, 2010 4:48 pm
adhesiv wrote:When trying to update tags on .m4a files i get the following error:
My bad, I simply forgot to enable it. Will be fixed.
Postby sindre_mehus » Tue Apr 27, 2010 4:51 pm
SpritHansi wrote:I can't get the chat to work in v4 beta 1. Yes, it's enabled in settings :-)
Anyone else seeing this? I've tested it with Opera, Safari, Firefox and IE. What browser and version are you using?
Postby SpritHansi » Tue Apr 27, 2010 4:59 pm
Opera v10.52 (latest) & Google Chrome v4.1
Regards
SpritHansi
SpritHansi
Postby sindre_mehus » Tue Apr 27, 2010 5:00 pm
Let me try to explain what changes was done with respect to ports.
I removed the option to differentiate between internal and public ports in UPnP port forwarding, as this was confusing for many non-techy users. So if you're using UPnP and/or a xxx.subsonic.org address, the internal and public ports must be the same.
Secondly, the default port on a Windows install is 80. On Linux, Mac, war and stand-alone install, the default port is 4040.
The .deb and .rpm installers will remember port overrides when upgrading, but all other installers will reset to default port.
Hope this was clarifying.
Postby kapz » Tue Apr 27, 2010 5:38 pm
So, is Subsonic supporting playing video now with the ffmpeg library? I would need to compile my own for Slackware.
Paid Subsonic user
Love my unRaid (~9.5TB): [url=http://lime-technology.com/forum/index.php?topic=2031.msg40351#msg40351]Pictures Here (Reply #82)[/url]
kapz
Postby donpearson » Tue Apr 27, 2010 7:35 pm
I sorted my port problems, had to reinstall.
Facebook Group:
donpearson
Return to Announcements
