Subsonic 4.5.beta1 released
Postby paradym3 » Tue Jun 21, 2011 9:53 pm
sindre_mehus wrote:
ccandreva wrote:Question: Why does sharing need a subsonic.org address ? My server has a static IP so I've never set one up, and didn't plan to.
For simplicity. The public IP is generally not known to the Subsonic server (and it also cannot know if it's dynamic or not) - whereas the subsonic.org address is known, it supports dynamically changing IPs, and it works both within your lan and from the outside.
Just upgraded the WAR file, works great. :D I am really interested in the sharing and Facebook/Twitter integration. As I host my own site and the DNS is handled by DynDNS wouldn't just the domain just need to be used instead of http://MyServer.subsonic.org? Is this expected in the final version, for non-Subsonic.org users to use sharing?
I understand on the LAN this could be a problem, but sharing via FB/Twitter would be over the WAN anyway.
Thank you,
Paradym3
paradym3
Postby ccandreva » Tue Jun 21, 2011 10:22 pm
I actually have a subnet for my house, so my subsonic server has the same dedicated IP no matter where I am.
But I would guess not too many people have that.
ccandreva
Request for Self administered URL Prefix
Postby Josh Hawley » Wed Jun 22, 2011 1:09 am
I see that you setup the linking for twitter/facebook to use the myserver.subsonic.org DNS name. While I agree that, as a default, it is a great option for most users(especially the non technical ones), I am one of those that would prefer not to use a subsonic.org host name for a variety of reasons.
Could you please add a setting that allows us to specify the appropriate IP/Host name that is used in shared links as a setting?
- Josh Hawley
Josh Hawley
Re: Request for Self administered URL Prefix
Postby Aethies » Wed Jun 22, 2011 2:02 am
Josh Hawley wrote:I see that you setup the linking for twitter/facebook to use the myserver.subsonic.org DNS name. While I agree that, as a default, it is a great option for most users(especially the non technical ones), I am one of those that would prefer not to use a subsonic.org host name for a variety of reasons.
- Josh Hawley
Personally, when you get connected, I don't like it displaying my local IP address. Would rather it just showed nothing.. hahah
Peace!
Aethies
Ubuntu Server 12.04
3,281 artists
9,432 albums
113,608 songs
2636.09 GB (10,769 hours)
Aethies
Postby courageousrobot » Wed Jun 22, 2011 3:53 am
Maybe I'm missing something here, but could we please have a way to limit users' video bitrate? My upload could handle the previous settings, but stress testing with 3000 kbps and 5000 kbps has showed some weaknesses.
I have around 60 users accessing my Subsonic server - many of which use it daily. Don't believe me?
Look:
The 5000 kbps is killing my pipe (FiOS 35/35) which was doing just fine previously.
Thank you so much for this amazing service, regardless!
courageousrobot
Postby Jokestr » Wed Jun 22, 2011 5:21 pm
Rolling back to 4.4 fixed my connection issue (though now I feel like I'm living in the past).
Maybe it my beautiful 64 bitness that's the issue, I know it caused subsonic to act differently in the past (though always better).
again, machine is OS X 10.6.7 64bit, my url would not connect using 4.5.1(beta).
"STATUS: xxxxxx.subsonic.org is registered, but could not connect to it. (ConnectTimeoutException)"
Jokestr
Postby tangx » Wed Jun 22, 2011 6:43 pm
Sharing is awesome but needs management.
Given that the goo.gl links never expire and that when you share something you have no idea who's playing it back. Things could get out of hand fast.
If you share a popular song on facebook it could get spread around and you'd never know since shared playback doesnt show up in your log. It'd just rape your bandwidth.
Need the ability to remove a share after it's created.
OR at least disable one share without disabling them all.
also,
once you create a share and someone goes to it. It fwd's to a link like
http://xxxx.xxxx.xxx.xxx/externalPlayer ... 52e617669&
This link can never be disabled and it can be shared with anyone. It's a permanent backdoor to your content without needing a login/pass that you have no control over.
tangx
Postby Aethies » Wed Jun 22, 2011 7:28 pm
tangx wrote:Sharing is awesome but needs management.
also,
These two points are exactly why I have disabled the ability to all my users. I second the suggestions. The ability to have the links expire, and two, hide the address...[/b]
Aethies
Ubuntu Server 12.04
3,281 artists
9,432 albums
113,608 songs
Aethies
Postby Josh Hawley » Wed Jun 22, 2011 7:54 pm
- Josh Hawley
Peace!
This is exactly why it should be an option; because there are lots of people out there that want to configure it in different ways =)
Josh Hawley
Postby Josh Hawley » Wed Jun 22, 2011 8:04 pm
also,
Yikes! That is a major security hole. Maybe add a link management page under settings where you can disable links manually as well as manage expiration timers?
Josh Hawley
Postby SirSid » Fri Jun 24, 2011 3:28 am
I also have the connection error running on a 32bit ubuntu instillation
SirSid
Postby Castius » Fri Jun 24, 2011 4:02 am
Anyone having trouble adding to playlist?
It would also be nice to be able to share playlist.
I also agree with sharing issues. We need to be able to manage this. It's hard enough when you know the user account. I can't think of what it would be like beyond that.
Castius
Postby itsthesource » Fri Jun 24, 2011 4:46 am
courageousrobot wrote:Maybe I'm missing something here, but could we please have a way to limit users' video bitrate? My upload could handle the previous settings, but stress testing with 3000 kbps and 5000 kbps has showed some weaknesses.
Look:
Eww...that's awful. You may want to try creating your own script to limit the bandwidth. In other words, pass the seek value, source file, bit rate, width & height. If the bitrate is higher than you'd like adjust the bitrate & resolution to a suitable value and issue your transcoding commands. That should solve your problem for now.
itsthesource
Postby GJ51 » Sat Jun 25, 2011 1:17 am
Hi gang,
I just got back from a break and did an install of 4.5 beta. I can't get any external players to work. Anyone else had any success/problems/fixes with the external player? Mine won't play music or video.
EDIT: Works in IE 9 but not in Chrome or FireFox
Postby Aethies » Sat Jun 25, 2011 4:00 am
GJ51 wrote:Hi gang,
Booo.. Mine too.. Getting Can't open MRL stream.. I am using Chromium in Gentoo. Will test this in windows.
Tested it in windows and get the same error. Interesting..
Aethies
Return to Announcements
