Subsonic 4.5 released
Error 2032 In JWplyaer When Sharing Links.
Postby jboy71 » Fri Aug 12, 2011 4:45 pm
When I share a link in facebook for example, I test the link and the jwplayer shows the error message, "Error 2032". Am I missing something here? I am logged in as admin with full privledges.
UPDATE: Thanks for all that responded to this question. Very important information and it appears others are having the same issue as me but under different circumstances. I am running subsonic on a windows 7 machine. What I did to resolve this issue is stop the subsonic service, renamed my original subsonic folder to origsubsonic, uninstalled subsonic, re-installed subsonic 4.5 fresh, took a fresh copy of the subsonic.script file(This fresh file essentially wipes out all user profiles) from the newly installed subsonic db folder, copied if over to my orgsubsonic folder, stopped the subsonic service again, deleted the subsonic folder, renamed origsubsonic to subsonic again, started the service and bam! No more Error 2032 errors for me.
NOTE: I Have customized my site quite a bit so I migrated alot of my original files over to 4.5 after using a comparison tool to add new code from 4.5 to my old 4.4 files. I supect my 4.4 subsonic.script file caused permission issues since that is one of the files I did not change when I copied over from 4.4.
jboy71
Postby fonsoy » Fri Aug 12, 2011 7:33 pm
GJ51 wrote:Updated from 4.5b2. Update went smoothly, only needed to renter Log on rights for the Subsonic service on Windows 2008 R2.
I notice that ffmpeg looks to be a recent verrsion, 7/28/11.
No problems found so far.
Thanks Sindre
Does there happen to be a small howto for this?
fonsoy
Postby bushman4 » Fri Aug 12, 2011 7:37 pm
For changing the logon info of the service? Yes, but you only need to do it if you did it in the past (ie, if you have music shares on a remote network PC or SAN).
But if you go into the services section of Computer Management and double click on the subsonic service, you can enter the account to run under on the "Log on" tab.
HTH,
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby Subsonic_User » Fri Aug 12, 2011 9:29 pm
Sparticuz wrote:F14 here,
Setting up Install Process
Examining subsonic-4.5.rpm: subsonic-4.5-2384.noarch
subsonic-4.5.rpm: does not update installed package.
Error: Nothing to do
Upgrading from 4.5b2
Basically the system thinks the beta is newer than the final and isn't updating it. if you run "rpm -Uvh subsonic-4.5.rpm --oldpackage" that will upgrade it.
Subsonic_User
Postby GJ51 » Fri Aug 12, 2011 11:37 pm
Thanks Sindre
This link has an illustrated guide to editing the Subsinic service in Windows.
http://monroeworld.com/android/subsonic/
This is only required if you are accessing files that are on a network share that require user permissions to access.
Postby daniell » Sat Aug 13, 2011 6:09 am
For RHEL /CentOS/Fedore.
To Upgrade from subsonic-4.5.beta2 to Subsonic 4.5, try this..
Backup folder var/Subsonic
Stop subsonic service
Start with uninstall subsonic
# yum remove subsonic
Install new
# yum install --nogpgcheck subsonic-4.5.rpm
Edit the file /etc/sysconfig/subsonic
SUBSONIC_ARGS="--port=4040 --https-port=443 --max-memory=1024"
Reboot
That should also keep all your settings..
Supermicro Intel(R) Core(TM) i7-3555LE CPU @ 2.50GHz, 4 cores 8gb ram
CentOS Linux 6.6 Server, jetty-6.1.x, java 1.7.0_71, Linux (143,2 MB / 437,5 MB) Subsonic 5.1
Supermicro Intel® Atom™ D510 4gb ram
Sophos Security Gateway UTM /v9
daniell
Postby rvandaalen » Sat Aug 13, 2011 3:16 pm
upgraded from beta2, works nicely on my unraid setup.
Is there anyone who has tried to share a movie file?
How can I control the bitrate and height+width of a movie file in my share settings? Standard a share plays files at very low unwatchable bitrate 128k when sharing and the hxw is off, any help?
rvandaalen
Postby GJ51 » Sat Aug 13, 2011 5:49 pm
Postby jaja » Sat Aug 13, 2011 9:52 pm
thenuma wrote:@jaja Install from command line do a
dpkg --install subsonic-4.5.deb
no uninstall neccesary
thanks but too late ;)
regards
jaja
jaja
Postby Hellscream » Sun Aug 14, 2011 2:20 am
WOOOOHOOOO :) finaly something good, everything working fine no errors at all. I didnt test FB shareing and i hope i never will :P.
Great job Sindre keep with good work +1.
Hellscream
Postby paulodell » Sun Aug 14, 2011 10:33 pm
I was running Beta2 on a MacBook and have now upgraded...all is well, I have noticed a small bug which means that the admin user cannot Share files?
If i create a user who can share files then login, that account has the Facebook and share buttons.
The admin does not have these buttons visible?
I do have a few accounts which have sharing disabled aswell.
Paul O'Dell
paulodell
Postby Hellscream » Sun Aug 14, 2011 10:37 pm
Actually admin can share files if u install SS 4.5 on machine without any previous data from earlier versions (but if u wanna keep users and all data u have than u are right) doesn't work.
Hellscream
Re: Subsonic 4.5 released
Postby paulodell » Mon Aug 15, 2011 6:40 pm
How do you remove the settings which stop this sharing from being shown?
SubWiji http://tinyurl.com/7sxwbfv Install http://subwiji.paulodell.co.uk
Transcode Step1 "ffmpeg -f mp3 -i %s -ab %bk -v 0 -f mp3 -"
Tremor Games http://www.tremorgames.com/?ref=59174
paulodell
Postby GJ51 » Mon Aug 15, 2011 7:06 pm
Just go to the Settings/Users and uncheck it from the users who have it enabled. This can be done for anyone except the admin.
Postby swocoom » Mon Aug 15, 2011 9:06 pm
paulodell wrote:How do you remove the settings which stop this sharing from being shown?
I think he ment the check boxes. They still show even if permissions for sharing are not there. This can be modified in the main.jsp file. Scroll down till you see:
<td ${class} style="padding-left:0.25em"><input type="checkbox" class="checkbox" id="songIndex${loopStatus.count - 1}"></td>
You need to add:
<c:if test="${model.user.shareRole}">
</c:if>
swocoom
Return to Announcements
