Subsonic Package for Synology NAS
Re: Subsonic Package for Synology NAS
Postby viand0x » Sat Jan 28, 2012 10:37 am
I tried with isub app an all works fine! I think substream is in cause...
viand0x
Postby gigon » Wed Feb 08, 2012 1:44 pm
Yes, just tested Substream... it is slow, doesn't support caching and you can't change a single bit...
the 3,99€ for iSub are totally worth it...
Subsonic Package for Synology DiskStations http://eg-blog.de
gigon
Postby Carl314 » Sun Feb 26, 2012 10:39 pm
I had Subsonic up and running on my 212, but I returned that and bought a 712+. I followed the prerequisites for installing Subsonic, and have Java SE for Embedded 6 installed.
But when I try to install the package, it appears to be downloading, but once it gets to 100%, it returns an error message saying: "failed to download".
Any ideas?
Cheers, Carl.
Carl314
Postby Carl314 » Fri Mar 02, 2012 11:34 pm
Just got it figured out. I installed the .spk file manually, and all is well.
Carl314
Postby gigon » Mon Mar 12, 2012 11:35 pm
hmm thanks for the hint.
I re-uploaded all .spk version to my dropbox, where the files are hosted, I hope it will work now.
gigon
Postby GewGaw » Wed Mar 14, 2012 2:20 am
Wow! Great job. Was able to walk through it and get it up and running no problem!
Just got one question. Is it possible (with transcoding disabled) to stream video content? I am getting a "Video not found or access denied:" message followed by a "stream?pathUtf8Hex=...." error.
Would love to stream video to my tablets.
GewGaw
ps... keep up the great work!
GewGaw
Postby gigon » Sun Apr 08, 2012 7:23 pm
I think Subsonic might not be the right Solution for that (yet?).
Also the Diskstation in not very powerful, so you can't transcode videos.
I have created a second player configured to play video in an external player installed on my PC (vlc), so Subsonic is just the source and everything else is done by vlc.
gigon
Postby gigon » Sun Apr 08, 2012 7:25 pm
I have created a new package (4.6-022) which includes tsquillarios MiniSub html5 interface from this topic.
more info at http://eg-blog.de
gigon
Postby JohnD76 » Wed Apr 11, 2012 6:54 am
How do I enable https for the Diskstation package?
John.
JohnD76
Postby gigon » Thu Apr 12, 2012 12:02 am
To access the html5 interface:
Type in your login name and password
Click “Remember me”
login to your standard Subsonic interface
change the url after the 4040 add /html5/ (hit Enter)
gigon
Postby orion » Fri May 25, 2012 1:50 am
Beautiful package gigon. I read your blog too. Great work!!
I have it working perfectly on my DS212+ except for transcoding. If I disable transcoding it streams mp3s without issue; CPU sits at around 2-10%... almost like I wasn't doing anything at all.
With tanscoding enabled (any kind, even lame for mp3->mp3) the CPU is pegged out at 100% and there are skips every few seconds. This is a bummer because my archive is in FLAC. The workaround I am thinking of doing is to run a script to create a new 128kbps mp3 version of my entire library (in a separate folder) on my NAS and point subsonic at that. It's not a big deal, just takes more space and the conversion will take a while. It's still worth it for me to be able to stream from my DS212+. :)
I am positive that the 2GHz cpu in this NAS is powerful enough to handle the transcoding at the playback bitrate but it seems like it tries to transcode the whole file at once to "get ahead" of the playback. What are your thoughts? Please let us know if you discover a workaround or solution to the transcoding problem; some way of buffering or wrapping the process so that it doesn't peg out at 100%.
orion
Postby gigon » Tue May 29, 2012 5:13 pm
hi orion,
first of all: you can not compare a 2GHz x86 desktop CPU with a 2GHz ARM... I own a 211+ (1.6GHz) and transcoding is far away from real time, so maybe you CPU is still too weak.
Second thing: Yes you are right. Subsonic always transcodes every file from start to end, no matter if you are skipping or stopping the track.
gigon
Postby gigon » Tue May 29, 2012 5:16 pm
I made a new package...
included
Subsonic 4.7 beta 1
MiniSub 1.9.7
Subtunes 0.9.4b
more info: eg-blog.de
gigon
Postby orion » Mon Jun 04, 2012 9:45 am
Thanks for the reply. For now it appears the best solution is to have a decent bitrate mp3 version of the songs in a separate folder on the NAS (if you are using FLAC or something) and stream from there without transcoding.
orion
Postby gigon » Wed Jun 06, 2012 12:16 pm
I can't see a way without pre-transcoding your music, or if you are using iSub oder the android app: Cache your music via Wifi, so you don't have to stream it when you are away, thats what I do.
gigon
Return to Announcements
