Subsonic 4.7.beta3 released
Re: Subsonic 4.7.beta3 released
Postby Castius » Sun Aug 05, 2012 3:59 am
OK i deleted everything in the sub sonic folder.
then copied subsonic.script and subsonic.data to the db folder
then restarted subsonic
entered my licence
Had to refresh the page to remove donation button at the top
Reset the default theme
Had to refresh the page to fix the header of the page
Rescan my media.
re installed to replace deleted files like transcode
Castius
Postby utopian » Sun Aug 05, 2012 6:58 am
installed fine by still showing some track listings on albums alpahbetically rather than in the correct order..? whats up ??
utopian
Postby naguchennai » Sun Aug 05, 2012 10:30 am
utopian wrote:installed fine by still showing some track listings on albums alpahbetically rather than in the correct order..? whats up ??
Yes i am also having samle problem... Not align by order....
Now sear is really fast...
naguchennai
Postby phazzard » Sun Aug 05, 2012 4:17 pm
I also just noticed on one album the songs were alphabetical instead of in track # order. I verified on the hard drive that the songs were tagged correctly with track numbers. When I clicked on Edit Tags within subsonic nothing was populated for these songs. I clicked suggest and it filled everything in correctly (Except the track numbers). I manually added the track numbers and now the track's display in the proper order. I have only seen it on one album so far and that was an easy fix for one album, it would not be an easy fix if I find additional albums with this error.
phazzard
Postby r0gue33 » Sun Aug 05, 2012 5:55 pm
Everything looks good except the playlists. The auto importing worked during the upgrade, with the following results:
1. Playlist will show to have 102 songs, imported 15
2. Manual import of the same 102 song playlist did not change the result. SS will validate the list has 102 songs, but show only 15. No log entries saying the paths are wrong.
3. Some playlists are still empty, even though showing x number of songs
Thanks for putting in the Show All playlists, is there a way to collapse it after expanding.
Thanks for all the hard work, SS is still my favorite music/vid app, no contest!
-Jeff
r0gue33
r0gue33
Postby BKKKPewsey » Sun Aug 05, 2012 6:34 pm
Another issue I have is that I have seemed to have lost my top rated albums :(
Edit: Ignore the above - user error as I took the opportunity to change the path names to UNC which broke the links in the db :oops:
After rescanning SS is still only reporting about 30% of the number of artists that 4.6 reported
With regard to the sorting
This with sort albums by year unselected
The 2 albums that are out of sequence are both double cd albums.
Another thing that is also different from 4.6 is that those albums are not listed in the album art display
With 4.6 if you put a cover.jpg in the root folder of the album it would display.
Postby an_otter » Sun Aug 05, 2012 11:10 pm
love the fix on the scanning, quick as can be now. i still can't seem to change themes anymore, and I haven't been able to since the last beta, but this is a definite improvement, thanks!
an_otter
Postby utopian » Mon Aug 06, 2012 7:45 am
Reverted back to 4.6 and displaying in orrect order....so what's the difference in the beta version
utopian
Postby lovebags » Mon Aug 06, 2012 11:38 am
+1 Yes this would be very handy. Better still would be to be able to re-order playlists and/or create playlist folders! :D
lovebags
Postby FoxBJK » Mon Aug 06, 2012 3:02 pm
I have a question regarding the new MiniSub included with this release. When I first run the MiniSub player and save my credentials, are they being held by the server application on my desktop, or stored within my browser?
FoxBJK
Postby Sparticuz » Mon Aug 06, 2012 3:19 pm
REST: Added support for HTTP Live Streaming.
Alright! Let's get some Android streaming going in the official app now!!!
Sparticuz
Postby Sparticuz » Mon Aug 06, 2012 3:27 pm
I'm using --context-path in my subsonic args and minisub doesn't work from clicking the link. (it looks like it doesn't honor the --context-path). The link in 'More' goes to hostname/mini/index.html whereas it should honor the context path and go to hostname/subsonic/mini/index.html
Sparticuz
Postby erik » Mon Aug 06, 2012 5:35 pm
Castius wrote:Updated from 4.6
Got 503 error
HTTP ERROR: 503
SERVICE_UNAVAILABLE
RequestURI=/index.view
I just encountered the same problem, and before I try Castius' solution, I wanted to know if this was a known problem, and if there's another way to solve it. Also, if this is a known problem, will there be a fix in a stable version?
Thanks again for a great service and all. =)
erik
Postby dakins » Tue Aug 07, 2012 12:27 am
I agree. Upgraded to this version and a bug I was having where some playlists wouldn't import was fixed so much thanks for that. The ability to sort the playlists, even alphabetically would be great!
dakins
Postby WildWalker » Tue Aug 07, 2012 7:48 am
Hello Sindre,
I see in the change log you have Added support for HTTP Live Streaming.
Does this mean that Subsonic will now stream to Apple devices without using the JWPlayer (as Apple has built in HLS support) using just the web interface.
Or is it something else?
Alan.
WildWalker
Return to Announcements
Users browsing this forum: No registered users and 35 guests
