Subsonic 4.7.beta3 released
Re: Subsonic 4.7.beta3 released
Postby armc » Tue Sep 11, 2012 1:51 pm
I have tried 4.7 beta 2 and 3. Both exhibit the same issue:
Movies and Music in locations seen by 4.6 are not seen by either of the two betas. That is a disappointment in many ways. That said, I would love to be able to use the new features. Any suggestions as to why it works in 4.6 but 4.7beta3 doesn't show any of my music or movies from several of my share locations?
A down grade to 4.6 fixed my issue of seeing my music.
v/r
ARM-C
armc
Postby beat » Tue Sep 11, 2012 2:01 pm
Thank you Sindre for your quick response.
I'm using windows 7, where would be the Tomcat directory ?
Please advise
beat
beat
Postby PieterB » Tue Sep 11, 2012 2:56 pm
beat wrote:Thank you Sindre for your quick response.
That wasn't a response to you BeatBoy, but a quick response to baaldemon (viewtopic.php?f=4&t=9998&start=165#p45491)
On your problem: for the time being, use the excellent Subsonic tag editor to add track numbers, or use the even more comprehensive MP3Tag software: http://www.mp3tag.de/en/
PB
PieterB
Postby GJ51 » Tue Sep 11, 2012 4:39 pm
Please advise
beat
C:\Program Files\Apache Software Foundation\Tomcat 6.0
Postby baaldemon » Tue Sep 11, 2012 7:20 pm
sindre_mehus wrote:Delete the "work" directory in Tomcat.
Interesting so this kinda worked. The third time was the charm.
So I removed the working dir and the .lck file after I stopped tomcat, started it back up, still saw the error. Rinse repeat same thing, but on the third try no more error. Not sure what happened differently that time but it seemed to do the trick.
Restart with same error as before
[2012-09-11 14:55:17,050] INFO DaoHelper - Checking database schema.
[2012-09-11 14:56:21,232] INFO DaoHelper - Done checking database schema.
[2012-09-11 14:56:21,449] INFO VersionService - Resolved local Subsonic version to: 4.7.beta3
[2012-09-11 14:56:21,796] INFO PlayerDao - Deleted 2 player(s) that haven't been used after Fri Jul 13 14:56:21 EDT 2012
[2012-09-11 14:56:21,898] INFO MediaScannerService - Automatic media library scanning scheduled to run every 1 day(s), starting at Wed Sep 12 03:00:00 EDT 2012
[2012-09-11 14:56:23,539] INFO PodcastService - Automatic Podcast update scheduled to run every 24 hour(s), starting at Tue Sep 11 20:30:00 EDT 2012
[2012-09-11 14:56:25,194] INFO NetworkService - Deleted port mapping for port 60443
[2012-09-11 14:56:26,530] INFO DaoHelper - Checking database schema.
[2012-09-11 14:56:26,705] INFO Schema25 - Database table 'version' not found.  Creating it.
[2012-09-11 14:56:26,719] ERROR DaoHelper - Failed to initialize database. - see subsonic.err for full details
[2012-09-11 14:56:26,914] INFO VersionService - Resolved local Subsonic version to: 4.6
Restart no error
[2012-09-11 15:06:11,450] INFO DaoHelper - Checking database schema.
[2012-09-11 15:06:20,659] INFO DaoHelper - Done checking database schema.
[2012-09-11 15:06:20,848] INFO VersionService - Resolved local Subsonic version to: 4.7.beta3
[2012-09-11 15:06:21,400] INFO MediaScannerService - Automatic media library scanning scheduled to run every 1 day(s), starting at Wed Sep 12 03:00:00 EDT 2012
[2012-09-11 15:06:22,958] INFO PodcastService - Automatic Podcast update scheduled to run every 24 hour(s), starting at Tue Sep 11 20:30:00 EDT 2012
[2012-09-11 15:06:24,780] INFO NetworkService - Deleted port mapping for port 60443
[2012-09-11 15:07:19,064] INFO VersionService - Resolved latest Subsonic final version to: 4.6
[2012-09-11 15:07:19,064] INFO VersionService - Resolved latest Subsonic beta version to: 4.7.beta3
baaldemon
Postby GJ51 » Tue Sep 11, 2012 8:52 pm
http://www.subsonic.org/pages/installation.jsp#war
Pretty simple install. I do it whenever a new version comes out that I want to test.
Postby beat » Thu Sep 13, 2012 10:15 am
Thank you PieterB for your reply.
I'm aware of tag editors. I have a rather large mp3 collection and this task would be time consuming.
With previous release album tracks were sorted in a correct order regardless of having track number on the tag or not.
beat
beat
Postby BKKKPewsey » Thu Sep 13, 2012 11:30 am
beat wrote:With previous release album tracks were sorted in a correct order regardless of having track number on the tag or not.
Only if the track # was in the filename - in which case auto-tag from file name will quickly add the the track #'s to your ID tags.
Postby sindre_mehus » Fri Sep 14, 2012 5:36 pm
I'm closing this topic now as the stable version of 4.7 is released.
Please head over to viewtopic.php?f=4&t=10236
Previous
Return to Announcements
