Subsonic 3.8.beta1 released
Re: Artist tag not displayed
Postby tomb » Sun Oct 11, 2009 11:39 pm
tomb wrote:3.7 & 3.8 Beta, Windows Installer version, XP-Pro, Firefox & IE, Java 6 Update 16
Not sure what conditions cause this. If the artist tags for all songs for a given artist are exactly the same, the artist is not displayed in the main window frame even though it is configured to be in Personal Settings for Browse & Playlist. If I edit tags and change one artist tag to be something different than the others and save, then artist tags will display for all songs. Click link for visual.
http://www.cruiseconnection-tours.com/artist_not_displayed.htm
Looking at the code, this is intentional. The Artist tag only gets displayed when there are multiple artists. Makes sense.
tomb
Postby agroni1888 » Mon Oct 12, 2009 9:00 am
Tested the Android application on HTC G1 and works perfect (just screen doesnt flip when you flip your phone).
agroni1888
Discogs search
Postby linuxman » Tue Oct 13, 2009 8:04 pm
Sindre thanks for making this functional again but the only issue is that when I do the discogs search all my results are a white box with a red x and won't display the actual artwork. But if I select one and then go back it actually loads and displays the image but is a crapshoot if it's the right one or not. This has been an issue the whole time with discogs and was why I always defaulted to using the amazon search which never had the issue. Any thoughts? 8)
linuxman
Two problems with Discogs cover search
Postby mgrant » Fri Oct 16, 2009 5:24 pm
I get this on one of my installs (machine1):
[2009-10-16 11:12:36,238] WARN CoverArtService - Failed to search for images at Discogs.
java.io.IOException: Method failed: HTTP/1.1 400 Bad Request
and this on my other install (machine2):
[2009-10-16 17:16:00,472] WARN CoverArtService - Failed to search for images at Discogs.
java.io.IOException: Not in GZIP format
Both installs are 3.8.beta1 standalone on kubuntu linux.
Sometime the search will work on machine 2 but it has never worked on machine 1 since installing 3.8.beta1.
-mg
mgrant
Re: Two problems with Discogs cover search
Postby mgrant » Fri Oct 16, 2009 5:33 pm
mgrant wrote:I get this on one of my installs (machine1):
Search for "Gov't Mule" "By A Thread" to duplicate this.
mgrant
Postby Eloquence » Fri Oct 16, 2009 10:14 pm
Great work on the newest version, it works perfectly on my end.
Just a real quick question about the Android app, I haven't got an Android phone myself but might soon. Can it be used with Subsonic in jukebox mode, so that it acts as a remote control for the Subsonic server? I briefly tried the streaming functionality on my colleague's HTC Hero and it's awesome!
Eloquence
Postby mgrant » Fri Dec 04, 2009 11:45 pm
bump...
anyone? I just re-installed my OS (kubuntu 9.10) and with it a clean install of standalone subsonic 3.8. I'm still getting this failure.
-mg
-mg
mgrant
Previous
Return to Announcements
Users browsing this forum: No registered users and 41 guests
