I like it a lot and think it's a great start. I'd like to do some work on the Music Library tab if that's ok. Thanks again though for this wonderful app. It's become my subsonic client of choice.
martman wrote:Wow. This is really awesome. Good work. Does it let you download full zipped albums yet? I can't figure out how to. If not, I would like to request that.
pha9992001 wrote:martman wrote:Wow. This is really awesome. Good work. Does it let you download full zipped albums yet? I can't figure out how to. If not, I would like to request that.
right click on an album/track
martman wrote:pha9992001 wrote:martman wrote:Wow. This is really awesome. Good work. Does it let you download full zipped albums yet? I can't figure out how to. If not, I would like to request that.
Can you be more specific? I can right click on any track and download it but nowhere can I right click on any album. In Music Library I can't right click on the albums in the left panel. If I left click on an album and bring up the songs of that album I can't click anywhere on the right side to download the full album. Does anyone else have this problem?
flacflac wrote:Hi, I am still unable to use this unfortunately due to the SSL warnings that pop up for every album that is loading - that's a lot of clicks to listen to one track sadly.Do you think there's a way for you to incorporate acceptance of SSL certificates so that it becomes more usable?
Great development, thank you!
pha9992001 wrote:Can you specify which OS is running on the system you have subair installed?
eli2k wrote:Finally got this working (after upgrading from 3.7). I was wondering if anyone had this problem. I have songs organized in Folder A (so there are songs in this folder), but then I have more folders inside Folder A, like Folder A\Folder B, and these folders also have songs. So I noticed that SubAir will only display songs if there are no directories inside, otherwise it will just list the directories. Just wondering if this is part of its design.
pha9992001 wrote:Yeah, this is a known issue. i was hoping no one noticed yet.I'm working on a fix.
pha9992001 wrote:martman wrote:pha9992001 wrote:martman wrote:Wow. This is really awesome. Good work. Does it let you download full zipped albums yet? I can't figure out how to. If not, I would like to request that.
The app is set up for the \artists\albums\ directory structure, sounds like your directory structure is \albums\
The left panel currently doesn't have the right-click enabled, but that is something I can look into adding.
