Subsonic 4.6.beta1 released
Re: Subsonic 4.6.beta1 released
Postby corbincc » Tue Nov 08, 2011 9:01 pm
EXACTLY.. that it was is going on... I now have all kinds of problems.. so i guess I have to delete the new transcode to ogg.. which sucks.. because i like it on the android player..
corbincc
Postby bile » Tue Nov 08, 2011 9:21 pm
bile wrote:Any chance of getting the tag manipulation issue fixed?
viewtopic.php?f=3&t=7777
Or modifying the prefix filter to work with non space delimited artist names? A_Perfect_Circle shouldn't be listed under A.
Sindre, can I get a comment on these bug fixes? Do you use the Sourceforge bug tracker or have some other place where issues can be submitted and tracked?
Thanks.
bile
Postby sindre_mehus » Wed Nov 09, 2011 10:24 am
GJ51 wrote:This does not work for mp3's because mp3's are not transcoded (normally), therefore new players pick up the mp3 to ogg transcoding defined for the Android Player and try to convert any mp3's to ogg on the desktop player, which of course won't pkay in JW like they will on Android.
The only way to make this work is to add back in a check box for "Default" that if unchecked prevents the new setting from automatically being applied to all Players. If there is a "Default" setting we could then just apply new settings to specific players without disabling new players. Alternatively, you could set up a transcoding area specifically for mobile devices that would not affect the desktop players.
Agreed, I probably need to put the "Default" option back again.
Postby Drashna » Thu Nov 10, 2011 6:03 am
corbincc wrote:EXACTLY.. that it was is going on... I now have all kinds of problems.. so i guess I have to delete the new transcode to ogg.. which sucks.. because i like it on the android player..
Since there are still two "commands", could you not transcode to MP3 and then transcode to OGG?
Oh, and now, every time I try to play video, the play just displays a long string of random characters. Even on files that played fine before. (on Windows Server 2003 x86)
Drashna
Postby Drashna » Thu Nov 10, 2011 6:30 am
Drashna wrote:Oh, and now, every time I try to play video, the play just displays a long string of random characters. Even on files that played fine before. (on Windows Server 2003 x86)
Looks like this is because the version of ffdshow for windows doesn't come with libx264 support compiled in. Reverting back to "ffmpeg -ss %o -i %s -async 1 -b %bk -s %wx%h -ar 44100 -ac 2 -v 0 -f flv -threads 0 -" works fine.
Edit: Did some searching and this build of ffdshow for windows works with the new command.
Drashna
Postby sindre_mehus » Thu Nov 10, 2011 9:28 am
That's strange because the ffmpeg that comes with the Subsonic Windows installer is indeed compiled with libx264 support. Can you please try again with the Subsonic-supplied ffmpeg and post the error that is written to c:\subsonic\subsonic.log when/if it fails?
If anyone else is experiencing the same problem I would be very much interested in hearing about it.
Thanks a lot :-)
Postby GJ51 » Thu Nov 10, 2011 9:59 am
When I first did the upgrade I ran into the same thing. Apparently the upgrade process didn't overwrite the version of ffmpeg that I had in the transcode subdirectory. Part of the problem was probably my own doing as I was trying different versions in the past. I just deleted and reinstalled the transcode directory and it fixed everything. Anyone having trouble should also be able to just download the latest build of ffmpeg for their OS and bring everything back up.
Postby sindre_mehus » Thu Nov 10, 2011 10:09 am
GJ51 wrote:I would also like to know what you do on the demo site to deal with the multitude of generated "Guest" Players that you must get. I know how to clear them through the dbview window, but most users probably don't. It would be very nice indeed if there was a daily routine that ran to clear the guest players. Perhaps a selection on the Players screen to auto clear once per day with an option to clear them manually from time to time.
Yeah, that's slightly awkward. I every now and then delete the players using db.view. I will look into automatically deleting obsolete players at regular intervals.
Postby Drashna » Thu Nov 10, 2011 5:07 pm
[11/10/11 8:55:08 AM PST]    INFO   PlaylistInputStream   admin listening to "Videos\tATu - All About Us (Uncensored 2005).mpg"
[11/10/11 8:55:08 AM PST]    DEBUG   TranscodeInputStream   Starting transcoder: [d:\internet\subsonic\transcode\ffmpeg] [-ss] [0] [-i] [\\UMMON\Videos\tATu - All About Us (Uncensored 2005).mpg] [-async] [1] [-b] [1000k] [-s] [384x288] [-ar] [44100] [-ac] [2] [-v] [0] [-f] [flv] [-vcodec] [libx264] [-preset] [superfast] [-threads] [0] [-]
[11/10/11 8:55:08 AM PST]    DEBUG   InputStreamReaderThread   (d:\internet\subsonic\transcode\ffmpeg) FFmpeg version SVN-r21231-Sherpya, Copyright (c) 2000-2010 Fabrice Bellard, et al.
[11/10/11 8:55:08 AM PST]    DEBUG   InputStreamReaderThread   (d:\internet\subsonic\transcode\ffmpeg) built on Jan 16 2010 05:42:31 with gcc 4.2.5 20080919 (prerelease) [Sherpya]
[11/10/11 8:55:08 AM PST]    DEBUG   InputStreamReaderThread   (d:\internet\subsonic\transcode\ffmpeg) libavutil 50. 7. 0 / 50. 7. 0
[11/10/11 8:55:08 AM PST]    DEBUG   InputStreamReaderThread   (d:\internet\subsonic\transcode\ffmpeg) libavcodec 52.47. 0 / 52.47. 0
[11/10/11 8:55:08 AM PST]    DEBUG   InputStreamReaderThread   (d:\internet\subsonic\transcode\ffmpeg) libavformat 52.47. 0 / 52.47. 0
[11/10/11 8:55:08 AM PST]    DEBUG   InputStreamReaderThread   (d:\internet\subsonic\transcode\ffmpeg) libavdevice 52. 2. 0 / 52. 2. 0
[11/10/11 8:55:08 AM PST]    DEBUG   InputStreamReaderThread   (d:\internet\subsonic\transcode\ffmpeg) libavfilter 1.15. 0 / 1.15. 0
[11/10/11 8:55:08 AM PST]    DEBUG   InputStreamReaderThread   (d:\internet\subsonic\transcode\ffmpeg) libswscale 0. 8. 0 / 0. 8. 0
[11/10/11 8:55:08 AM PST]    DEBUG   InputStreamReaderThread   (d:\internet\subsonic\transcode\ffmpeg) libpostproc 51. 2. 0 / 51. 2. 0
[11/10/11 8:55:08 AM PST]    DEBUG   InputStreamReaderThread   (d:\internet\subsonic\transcode\ffmpeg) [mpeg @ 003de340]max_analyze_duration reached
[11/10/11 8:55:08 AM PST]    DEBUG   InputStreamReaderThread   (d:\internet\subsonic\transcode\ffmpeg) Input #0, mpeg, from '\\UMMON\Videos\tATu - All About Us (Uncensored 2005).mpg':
[11/10/11 8:55:08 AM PST]    DEBUG   InputStreamReaderThread   (d:\internet\subsonic\transcode\ffmpeg) Duration: 00:03:37.20, start: 0.220000, bitrate: 1421 kb/s
[11/10/11 8:55:08 AM PST]    DEBUG   InputStreamReaderThread   (d:\internet\subsonic\transcode\ffmpeg) Stream #0.0[0x1e0]: Video: mpeg1video, yuv420p, 352x288 [PAR 178:163 DAR 1958:1467], 1150 kb/s, 25 fps, 25 tbr, 90k tbn, 25 tbc
[11/10/11 8:55:08 AM PST]    DEBUG   InputStreamReaderThread   (d:\internet\subsonic\transcode\ffmpeg) Stream #0.1[0x1c0]: Audio: mp2, 44100 Hz, 2 channels, s16, 256 kb/s
[11/10/11 8:55:08 AM PST]    DEBUG   InputStreamReaderThread   (d:\internet\subsonic\transcode\ffmpeg) d:\internet\subsonic\transcode\ffmpeg: unrecognized option 'preset'
Fortunately, it's easy to test, as when I downloaded the other ffdshow exe, I renamed it and kept the original too. Does this for every non-FLV video file. Redownloaded the transcode pack, just incase. Still errors out every time. And removing the "-vcodec libx264 -preset superfast" section allows for playback.
Drashna
Postby sindre_mehus » Thu Nov 10, 2011 5:22 pm
This log is from the old ffmpeg. Try running the installer again, making sure that no ffmpeg processes are running when you do it.
Cheers
Postby Drashna » Fri Nov 11, 2011 8:21 am
Redownloaded the "Transcode pack v1.1" and got the same results:
[11/11/11 12:16:28 AM PST]    DEBUG   TranscodeInputStream   Starting transcoder: [d:\internet\subsonic\transcode\ffmpeg] [-ss] [0] [-i] [\\UMMON\Videos\TV Shows\The Big Bang Theory\Season 05\The.Big.Bang.Theory.S05E09.The.Ornithophobia.Diffusion.avi] [-async] [1] [-b] [1000k] [-s] [624x352] [-ar] [44100] [-ac] [2] [-v] [0] [-f] [flv] [-vcodec] [libx264] [-preset] [superfast] [-threads] [0] [-]
[11/11/11 12:16:28 AM PST]    DEBUG   InputStreamReaderThread   (d:\internet\subsonic\transcode\ffmpeg) FFmpeg version SVN-r21231-Sherpya, Copyright (c) 2000-2010 Fabrice Bellard, et al.
[11/11/11 12:16:28 AM PST]    DEBUG   InputStreamReaderThread   (d:\internet\subsonic\transcode\ffmpeg) built on Jan 16 2010 05:42:31 with gcc 4.2.5 20080919 (prerelease) [Sherpya]
[11/11/11 12:16:28 AM PST]    DEBUG   InputStreamReaderThread   (d:\internet\subsonic\transcode\ffmpeg) libavutil 50. 7. 0 / 50. 7. 0
[11/11/11 12:16:28 AM PST]    DEBUG   InputStreamReaderThread   (d:\internet\subsonic\transcode\ffmpeg) libavcodec 52.47. 0 / 52.47. 0
[11/11/11 12:16:28 AM PST]    DEBUG   InputStreamReaderThread   (d:\internet\subsonic\transcode\ffmpeg) libavformat 52.47. 0 / 52.47. 0
[11/11/11 12:16:28 AM PST]    DEBUG   InputStreamReaderThread   (d:\internet\subsonic\transcode\ffmpeg) libavdevice 52. 2. 0 / 52. 2. 0
[11/11/11 12:16:28 AM PST]    DEBUG   InputStreamReaderThread   (d:\internet\subsonic\transcode\ffmpeg) libavfilter 1.15. 0 / 1.15. 0
[11/11/11 12:16:28 AM PST]    DEBUG   InputStreamReaderThread   (d:\internet\subsonic\transcode\ffmpeg) libswscale 0. 8. 0 / 0. 8. 0
[11/11/11 12:16:28 AM PST]    DEBUG   InputStreamReaderThread   (d:\internet\subsonic\transcode\ffmpeg) libpostproc 51. 2. 0 / 51. 2. 0
[11/11/11 12:16:28 AM PST]    DEBUG   InputStreamReaderThread   (d:\internet\subsonic\transcode\ffmpeg) Input #0, avi, from '\\UMMON\Videos\TV Shows\The Big Bang Theory\Season 05\The.Big.Bang.Theory.S05E09.The.Ornithophobia.Diffusion.avi':
[11/11/11 12:16:28 AM PST]    DEBUG   InputStreamReaderThread   (d:\internet\subsonic\transcode\ffmpeg) Duration: 00:21:05.68, start: 0.000000, bitrate: 1161 kb/s
[11/11/11 12:16:28 AM PST]    DEBUG   InputStreamReaderThread   (d:\internet\subsonic\transcode\ffmpeg) Stream #0.0: Video: mpeg4, yuv420p, 624x352 [PAR 1:1 DAR 39:22], 23.98 tbr, 23.98 tbn, 23.98 tbc
[11/11/11 12:16:28 AM PST]    DEBUG   InputStreamReaderThread   (d:\internet\subsonic\transcode\ffmpeg) Stream #0.1: Audio: mp3, 48000 Hz, 2 channels, s16, 128 kb/s
[11/11/11 12:16:28 AM PST]    DEBUG   InputStreamReaderThread   (d:\internet\subsonic\transcode\ffmpeg) d:\internet\subsonic\transcode\ffmpeg: unrecognized option 'preset'
Drashna
Postby sindre_mehus » Fri Nov 11, 2011 11:37 am
The transcoding pack is obsolete, as the transcoders now are bundled with the installer.
Internal error
Postby herbman » Fri Nov 11, 2011 4:52 pm
I'm seeing this issue after having the beta running for some days and then opening its window again and clicking the 'Playing' button. (attached screenshot)
Edit: It went away after a restart. Let me know if you need any logs.
herbman
Postby GJ51 » Fri Nov 11, 2011 6:04 pm
Drashna wrote:Redownloaded the "Transcode pack v1.1" and got the same results:
You might also try:
ffmpeg - go to http://ffmpeg.zeranoe.com/builds/ and download the latest static build for your system. This site is for Windows builds. Check http://www.ffmpeg.org/download.html for other OS's. I just extracted the ffmpeg.exe and replaced the file in C:\Subsonic\transcode
Postby jboy71 » Sat Nov 12, 2011 8:34 am
Am I missing something. I cannot find the google+ share feature. Maybe I am just sleep deprived. Can someone set me straight here? Thanks in advance.
JC
jboy71
Return to Announcements
